How to... run dual cam simultaneously?
General discussions, information and support on satellite equipment
UniVerseHub
Super member
Super member
Has thanked: 1 time
Been thanked: 19 times
United States of America
Post by UniVerseHub »
Hello everyone,
I need to run two different cams at the same time...
the issue is that when i select one, the other stops ... but i need them both active
is there a "how to" to this problem?
Any help would be greatly appreciated
Been thanked: 1668 times
Re: How to... run dual cam simultaneously?
Black Hole Image allows you to select a cam for a specific provider via the autocam fuction
UniVerseHub
Super member
Super member
Has thanked: 1 time
thanks for your answer, but the cams must be active anytime... not just when you zap... the device has two tuners ... one from cable and one from sat.... i need them to be active all the time...
UniVerseHub wrote: ↑11 Nov 2022, 00:12 thanks for your answer, but the cams must be active anytime... not just when you zap... the device has two tuners ... one from cable and one from sat.... i need them to be active all the time...
Nothing
You can use two readers in one oscam
UniVerseHub
Super member
Super member
Has thanked: 1 time
yes, that'd be simple, wouldn't it!? but the problem is that ... one must read a card in the box and one is coming from a plugin.... so... osc@m, with reader must be on always ... but when i select the cam from the plugin obviously the osc@m goes off
tct_man
Been thanked: 5 times
India
Post by tct_man »
buy another box & share with oscam to the main box..
mubiscapers
Post by mubiscapers »
I appreciate your response, but the cameras must be active at all times, not just when you zap. The device has two tuners, one for cable and one for satellite, so I need them to be active constantly.
Here’s how to make the CAM stay active all the time:
✔ 1. Make sure the CAM runs as a persistent service
On Enigma2 (VU+, Dreambox, Octagon, etc.):
Menu → Plugins → Softcam / Softcam Setup
– Select your CAM (OSCam / CCcam)
– Press Green = Start
– Press Yellow = Autostart = ON
This makes the CAM always active, even without watching TV.
✔ 2. Disable “Restart CAM on channel change”
Some images (OpenATV, OpenPLI, VTi) have an option:
Menu → Setup → Usage & GUI → Channel selection → Restart CAM on zap
→ Set to: OFF
If this is ON, the CAM only works when you zap.
✔ 3. Check OSCam configuration
In OSCam web interface:
Go to
Configuration → Global
Make sure:
restart_after_crash = 1
disablelog = 0
preferlocalcards = 1
And most importantly:
keepalive = 1
This prevents OSCam from going idle.
✔ 4. Dual tuner setup (important!)
For both tuners to stay active:
Menu → Setup → Service Searching → Tuner Configuration
– Configure Tuner A = Satellite
– Configure Tuner B = Cable
→ Make sure both are Enabled and Connected.
If one tuner is idle, some images stop the CAM for that tuner.
✔ 5. If using CCcam → Switch to OSCam
CCcam often sleeps when not zapping.
OSCam stays active 24/7 → best for dual tuner setups.
Return to “Satellite Equipment”
