Gcam SRT2020 Videocon Plugin Ok 100%
- admin
- SF FOUNDER
- Has thanked: 1665 times
- Been thanked: 422 times
Good News SRT2020 Videocon Plugin Ok 100%
The paths of the file Gcam 2.1 r0 emu -SH4 are move by DCC to the track
usr / emu or var / emu
The paths of the file config are move it to the track as well
usr / keys or var / keys
etc / tuxbox / config
Depending on the file path of the version Which works on them
gcam on
Enjoy
gcam on
Enjoy
Always Press THANKS button
Re: Gcam SRT2020 Videocon Plugin Ok 100%
Download plugin ,unzip the file and put it in folder named ,,plugin,, .after this copy plugin folder and paste in USB.connect USB with ur box backside.u will see update plugin option on ur tv screen.than press ok to install new plugin.when plugin install reboot ur box , u will see new plugin installed.
For putting c_line in this new plugin,connect ur box with computer through router.
On computer u will need a ,, DCC ,, programe,Dcc programme will help u to put ur c_line in gcam.
- Has thanked: 14362 times
- Been thanked: 1660 times
Great Guide Line @aatee Broaatee wrote: ↑06 Jun 2022, 18:40 Download plugin ,unzip the file and put it in folder named ,,plugin,, .after this copy plugin folder and paste in USB.connect USB with ur box backside.u will see update plugin option on ur tv screen.than press ok to install new plugin.when plugin install reboot ur box , u will see new plugin installed.
Sir app k deye ho a plugin install krne k bad show nhe ho rhe plz guide me
using this method usb detected but showa nop option on screen to udate how to fixaatee wrote: ↑06 Jun 2022, 18:40 Download plugin ,unzip the file and put it in folder named ,,plugin,, .after this copy plugin folder and paste in USB.connect USB with ur box backside.u will see update plugin option on ur tv screen.than press ok to install new plugin.when plugin install reboot ur box , u will see new plugin installed.
- admin
- SF FOUNDER
thakks problem solved locked the topicadmin wrote: ↑12 Sep 2022, 10:33Download plugin ,unzip the file and put it in folder named ,,plugin,, .after this copy plugin folder and paste in USB.connect USB with ur box backside.u will see update plugin option on ur tv screen.than press ok to install new plugin.when plugin install reboot ur box , u will see new plugin installed.
Video con working then share some screenshot for others memberaa7590 wrote: ↑12 Sep 2022, 23:03thakks problem solved locked the topicadmin wrote: ↑12 Sep 2022, 10:33Download plugin ,unzip the file and put it in folder named ,,plugin,, .after this copy plugin folder and paste in USB.connect USB with ur box backside.u will see update plugin option on ur tv screen.than press ok to install new plugin.when plugin install reboot ur box , u will see new plugin installed.
Regarding
videocon full ok nowShahid Geo wrote: ↑13 Sep 2022, 01:14Video con workingaa7590 wrote: ↑12 Sep 2022, 23:03thakks problem solved locked the topicadmin wrote: ↑12 Sep 2022, 10:33
Regarding
