DM800 HD - ERR01 NO CA FOUND
- elprofesor
- Active Member
- Has thanked: 6 times
- Been thanked: 14 times
Hello,
I flashed my dreambox DM800 HD with the openpli image ( openpli-2.1-beta-dm800-20140510.npi) and now i get the error 'ERR01 NO CA FOUND' when i boot it. It cannot go to dhcp mode so it's not accessible over network. Could you please advise what is the error and suggest any solutions?
Many thanks!
Many thanks!
- Has thanked: 14359 times
- Been thanked: 1668 times
Re: DM800 HD - ERR01 NO CA FOUND
yes, this mini usb port, is the serial port for this receiver. you can flash through serial, a correct one image for your receiver, and recover it.elprofesor wrote: ↑06 May 2023, 22:42 Hello,
Many thanks!
also,there was a recovery tool by yassinov, which had the bootloader for most dmm models (original and clone
- Zaam
- Has thanked: 375 times
- Been thanked: 220 times
Best tool to use is Japhar Flasher, this is a patched Dreamup.
Connect both Micro USB and ethernet cable fill out the ip ranges. and select the USB cable port.
Power off the SE then click connect in japhar flasher then power on the SE.
It should then connect and allow you to flash an image
- admin
- SF FOUNDER
- Has thanked: 1662 times
- Been thanked: 422 times
Hi thanks for the post
Dreambox OptiFlasher Enigma2 EDition [DM800/DM800SE]
Version 1.0.3
Main Features:
-Performing IMAGE Writing Operation [NFI]
-Performing IMAGE Backup Restore [NFI]
-Performing Boot Loader Writing/Update Operation [NFI]
-Performing Manual/Auto Reboot
Best regards , yassinov
Hope solve your problem
Version 1.0.3
Main Features:
Always Press THANKS button
- elprofesor
- Active Member
Hello,
Many thanks for the prompt reply and for your help, really appreciated! Do you also have a link for the right image for my box? My bootloader is version 84.
Best regards!
Best regards!
- admin
- SF FOUNDER
In Image :elprofesor wrote: ↑06 May 2023, 23:13 Hello,
Best regards!
- CCcam 2.2.1
- Mgcamd 1.35a
- Green Button to use plugin Dream cam Center
- New --oo--s for Emu's
DOWNLOAD
http://www.mediafire.com/?i7d551wpnsf395n
- elprofesor
- Active Member
Dear admin,
Many thanks for sharing the image with me. I accidentally flashed the original openpli image to my cloned box and I am now unable to use Dreamup in order to reflash the box using both serial and rj45 cables. Hopefully, the OptiFlasher tool can do the job.
Best regards!
Best regards!
- elprofesor
- Active Member
- elprofesor
- Active Member
Hello all,
I managed to successfully flash that image but I still get the same error. Do I need to flash another image? Or do I need to flash bootloader for sim 2.01 after flashing the image? Many thanks for your help!
- elprofesor
- Active Member
Screenshot attached.
Sim 201 team 84B
Sim 201 team 84B
- 346109103_525802916250023_8493877329353231403_n.jpg (104.03 KiB) Viewed 3859 times
