Edision OS Nino Plus OSCAM Help
Multics config Download & Config Profiles
Iznogoud
Has thanked: 3 times
Been thanked: 13 times
Portugal
Post by Iznogoud »
I have an Edision OS Nino Plus reception box, I need the IPK file compatible with my OSCAM service, but my provider doesn't help me and I don't know if the service is configured correctly.
I have already the files , arm file, oscam.conf ; oscam.server ; oscam.user
Can you give me a help?
Been thanked: 1668 times
Re: Edision OS Nino Plus OSCAM Help
Which image used you currently ??
Rizwan awan
Has thanked: 41 times
Been thanked: 425 times
Post by Rizwan awan »
try to install latest Oscam through plugins download , then replace the files which you have
Wetek Play2
Octagon SF8008
Vu+ Solo2
Dreambox 800HD
Iznogoud
Portugal
Post by Iznogoud »
The Founder wrote: ↑27 Dec 2022, 21:34 Which image used you currently ??
OpenATV 6.4 for Edision OS nino plus "openatv-6.4-osninoplus-20221118_usb.zip" from http://images.mynonpublic.com/openatv/6 ... osninoplus
And following the steps from
https://www.enigma2.net/image-openatv-6 ... nino-plus/
Iznogoud
Portugal
Post by Iznogoud »
Rizwan awan wrote: ↑27 Dec 2022, 22:05 try to install latest Oscam through plugins download , then replace the files which you have
because that's what I've been doing and how it doesn't work and that's why I've been asking for help. :D
Iznogoud wrote: ↑28 Dec 2022, 00:10
Helo donwload this file put in temp folder via dcc or other ftp apps
How to install
Go to software management and there extension install showing there softcam feed name ipk and press ok and install started after reboot box then go to plugins select softcams all showing here
https://www.mediafire.com/file/qpdqlr1xugjqm1k/OpenATV_softcam_feed_v9.0-mySATBOX.TV.ipk/file
Iznogoud
Portugal
Post by Iznogoud »
The Founder wrote: ↑28 Dec 2022, 08:33
How to install
Hello again
I did a new installation of all OpenATV 6.4 on my OS Nino Plus box
I installed the IPK file you sent me. It was successfully installed as you can see in the image, Take a look At the images I attached
I Reboot the Box
The OSCAM menu does not appear nor the respective files that could replace the files. Take a look At the images I attached
How can I resolve this?
Thanks again
Iznogoud wrote: ↑29 Dec 2022, 05:02
How to install
Hello again
I Reboot the Box
Thanks again
Its softcam feed done installed
Now you go to menu and see there plugins option press green button for downloading plugins after selecting softcam there show latest oscam emu ncam emu mgcam cccam all softcams press ok and install after go to softcam manager select softcam and putin configuration reboot box
admin
SF FOUNDER
SF FOUNDER
Has thanked: 1662 times
Been thanked: 422 times
Post by admin »
You have to almost done just follow this
Menu/Plugin
Iznogoud
Portugal
Post by Iznogoud »
Thanks for the help so far.
I'm a little lost at this stage, as there are several options and I don't know which one to choose in order to be compatible.
I have already tried one of them, with the following steps.
1 - I downloaded the plugin.
2 - Replaces the arm file and kept the original file name
3 - Replace oscam.conf, oscam.user and oscam.server files
4 - I restarted the box
5 - I was not successful in decoding the channels
How do you think I can move forward?
Return to “Multics Download & Config”
