طلب دامب خام لجهاز TIGER ONE MILLION EYES V1
- chaffari habib
- Active Member
- Has thanked: 1 time
- Been thanked: 2 times
Hello,
I need the recovery firmware or original RAW dump for:
Receiver: TIGER ONE MILLION EYES V1
Board: FH26-2D4G-V1
Board date: 20210701
Flash chip: GD25Q32, 4 MB
The receiver is stuck on BOOT after a wrong 16 MB GD25Q128 dump was programmed by mistake.
I need either:
1. RECOVERY TIGER ONE MILLION-V1.01.bin compatible with GD25Q32, or
2. A complete original 4 MB RAW dump, exactly 4,194,304 bytes, from the same board.
Please do not send a 16 MB GD25Q128 dump or a firmware file unless it is confirmed compatible with this board.
Board: FH26-2D4G-V1
I need either:
- Has thanked: 14339 times
- Been thanked: 1649 times
Re: طلب دامب خام لجهاز TIGER ONE MILLION EYES V1
- chaffari habib
- Active Member
merci de votre reponse
Le transfert s'effectue-t-il via USB ou à l'aide du looder
- chaffari habib
- Active Member
RS232 flasher / Ali Upgrade Tool
Try with 232 if not work box
Then use programmer flash
- chaffari habib
- Active Member
Thank you for the files. My receiver stays at BOOT and UART reports "verify code signature failed". Ali Upgrade Tool remains at "Sending upgrade request to box...".
Are V4.73 and V4.76 intended for direct SPI programming, or must they be loaded through RS232 using the Tiger loader? Are they compatible with board FH26-2D4G-V1 (20210701)?
- chaffari habib
- Active Member
Thank you; the issue has been resolved and the device is working again. Thanks for your help
chaffari habib wrote: ↑27 Oct 2026, 14:58 Thank you; the issue has been resolved and the device is working again. Thanks for your help
