Feeds brutos de jogos de futebol
Ola pessoal, alguem sabe se ainda é possivel conseguir captar feeds brutos de jogos do brasileirao e europeus com antenas parabolica e receptores tipo octagon, ou algum outro? Sei que conseguiam antes, nao sei se ainda isso é possivel com as novas tecnologias implantando pelas empresas de transmissao. Se poderem me ajudar agradeco.
- Has thanked: 14329 times
- Been thanked: 1640 times
Re: Feeds brutos de jogos de futebol
Yes, it is still possible to receive some sports feeds via satellite, including raw football feeds, but it is much more difficult nowadays than it was in the past.
Many feeds now use encryption, different transmission standards, and professional contribution systems, and some are only active during the event. It depends a lot on the satellite, frequency, band, coverage in your area, and the equipment you are using.
With a suitable satellite dish and a professional receiver supporting DVB-S2/S2X and the required codecs, there are still possibilities of finding occasional feeds. It is worth following communities and websites that publish feed frequencies and updates in real time.
