Hello guys,
I was updating my MS-7070 diamond decoder when power suddenly went off. It now only says "BOOT" and does not fully power on.
I did some google searched and found that for some mediast, starsat and tiger models in boot lock, using an update file in a FAT32 USD drive and renaming the bin file to update.bin (or rom.bin, flash.bin, recovery.bin, upgrade.com, ec) and repeatedly tapping the power button (or holding down) would force decoder to recover from USB.
I did these over several day with no luck. I tried all ways of renaming bin file and none gets picked up by decoder, or perhaps decoder does not pick up the USB drive. Am I doing this correctly?
I also found from google, that some decoders fail to recover from USB and so requires a chip flash using a flash dump file.
I hav searched everywhere for the exact dump file for MS-7070 diamond and not found one.
Can someone here help please share the dump file?
Would someone who owns the same model be kind enough to copy for me their flash dump and share?
Plz help.
Armigo
MEDIASTAR MS-7070 DIAMOND BOOT ERROR
- Has thanked: 14360 times
- Been thanked: 1669 times
Re: MEDIASTAR MS-7070 DIAMOND BOOT ERROR
armigo wrote: ↑11 Oct 2026, 16:19 Hello guys,
Plz help.
Armigo
USB Boot Recovery Steps
1. Prepare a USB Drive: Format a USB flash drive to FAT32.
2. Rename the File: Download the correct rescue/software or dump file (such as .bin or .rar) for the MediaStar MS-7070 Diamond from trusted sources like SatDL. Rename the primary update file to the specific recovery name required by the bootloader (often rom.bin or force.bin depending on the firmware version).
3. Insert USB: Plug the USB drive into the USB port of the MS-7070 Diamond while it is powered off.
4. Trigger Recovery Mode: Press and hold the OK button or Power button on the front panel (or remote, depending on prompt) while plugging in or turning on the power switch, until the screen or front panel shows the USB upgrade/recovery progress.
5. Wait for Completion: Let the receiver complete the flash process and reboot automatically. Do not unplug power during this time.
