Unofficial OpenBH 6.0 images
Has thanked: 14329 times
Been thanked: 1640 times
05.09.2026 - OE 6.0 Built 002
I build only those images abandoned by OpenBH ! for STB's I have
and I care about them ! Images are built without feed-server witch
is eventualy atached from OpenVIX ! I choose to built and publish
only in the case of perfect identity for feed-server ... same STB,
same Kernel vesion, same OE version , same OE built number.
Mut@nt HD51 : https://mega.nz/file/PwtwRL6D#J42BHIipE ... R0dU7HX7H0
Amiko Viper 4k Combo : https://mega.nz/file/O4V00bCK#4nCqp6gbp ... cYwqKyq_LU
Amiko Viper 4k V20 : https://mega.nz/file/S18nXC4R#oRYY6VjvQ ... d6_MNVsXbw
Amiko Viper 4k V30 : https://mega.nz/file/6htxQZiK#ZgybUg9xO ... aPuSGF5whY
Amiko Viper 4k V40 : https://mega.nz/file/mxFjCbBI#9iU2uk4xY ... RGDPBrzVE0
Zgemma H9S SE : https://mega.nz/file/mltzwZiC#9s7dtfwrG ... sOIITCMVn8
Some STB models were built but ... excluded !
Edision OS Mio 4k and 4K+ - missing compatible feed server
Zgemma H9S - will be published later
- installed clean
- scanned clean
- viewing with sound and image OK
- plugin server active
- I downloaded and installed PlutoTV that starts
- play of PlutoTV streams does not work
- I installed Chiefp settings
- I tested IPTV stream play and it is functional!
- I jumped through Multiboot to OpenATV - OK!
Return to “Image's”
