Google Pixel 10 Pro XL review
NETWORK Technology
GSM / HSPA / LTE / 5G
LAUNCH Announced 2025, August 20
Status Available. Released 2025, August 28
BODY Dimensions 162.8 x 76.6 x 8.5 mm (6.41 x 3.02 x 0.33 in)
Weight 232 g (8.18 oz)
Build Glass front (Gorilla Glass Victus 2), glass back (Gorilla Glass Victus 2), aluminum frame
SIM · Nano-SIM + eSIM
· eSIM + eSIM (8 or more, max 2 at a time; USA)
IP68 dust tight and water resistant (immersible up to 1.5m for 30 min)
DISPLAY Type LTPO OLED, 120Hz, HDR10+, 2200 nits (HBM), 3300 nits (peak)
Size 6.8 inches, 109.7 cm2 (~88.0% screen-to-body ratio)
Resolution 1344 x 2992 pixels, 20:9 ratio (~486 ppi density)
Protection Corning Gorilla Glass Victus 2, Mohs level 4
PLATFORM OS Android 16, up to 7 major Android upgrades
Chipset Google Tensor G5 (3 nm)
CPU Octa-core (1x3.78 GHz Cortex-X4 & 5x3.05 GHz Cortex-A725 & 2x2.25 GHz Cortex-A520)
GPU PowerVR DXT-48-1536
MEMORY Card slot No
Internal 256GB 16GB RAM, 512GB 16GB RAM, 1TB 16GB RAM
UFS 4.0
MAIN CAMERA Triple 50 MP, f/1.7, 25mm (wide), 1/1.31", 1.2µm, dual pixel PDAF, OIS
48 MP, f/2.8, 113mm (periscope telephoto), 1/2.55", dual pixel PDAF, OIS, 5x optical zoom
48 MP, f/1.7, 123˚ (ultrawide), 1/2.55", dual pixel PDAF,
Features Multi-zone Laser AF, LED flash, Pixel Shift, Ultra-HDR, panorama, Best Take, Zoom Enhance
Video 8K@30fps (via cloud-based upscaling), 4K@24/30/60fps, 1080p@24/30/60/120/240fps; gyro-EIS, OIS, 10-bit HDR
SELFIE CAMERA Single 42 MP, f/2.2, 17mm (ultrawide), PDAF
Features HDR, panorama
Video 4K@30/60fps, 1080p@30/60fps
SOUND Loudspeaker Yes, with stereo speakers
3.5mm jack No
COMMS WLAN Wi-Fi 802.11 a/b/g/n/ac/6e/7, tri-band
Bluetooth 6.0, A2DP, LE, aptX HD
Positioning GPS (L1+L5), GLONASS, GALILEO, BDS, QZSS, NavIC
NFC Yes
Radio No
USB USB Type-C 3.2
FEATURES Sensors Fingerprint (under display, ultrasonic), accelerometer, gyro, proximity, compass, barometer, thermometer (skin temperature)
Ultra Wideband (UWB) support
Satellite SOS service
BATTERY Type Li-Ion 5200 mAh
Charging 45W wired, PD3.0, PPS, 70% in 30 min
25W wireless (magnetic), Qi2
Reverse wired
Bypass charging
MISC Colors Moonstone, Jade, Porcelain, Obsidian
Models G45RY, GUL82, GYPW4
SAR 0.99 W/kg (head) 0.99 W/kg (body)
SAR EU 0.99 W/kg (head) 1.39 W/kg (body)
Price $ 519.90 / € 835.83 / £ 758.99 / ₹ 119,999
OUR TESTS Performance AnTuTu: 1423216 (v10), 1548670 (v11)
GeekBench: 6497 (v6)
3DMark: 3332 (Wild Life Extreme)
Display 2340 nits max brightness (measured)
Loudspeaker -25.3 LUFS (Very good)
Battery
Active use score 12:29h
EU LABEL Energy Class B
Battery 48:39h endurance, 1000 cycles
Free fall Class A (270 falls)
Repairability Class B
- Has thanked: 14363 times
- Been thanked: 1659 times
