Smart Tube Apk For Smart Tv Free Download
You can get here some interesting stuff and test it before official release.
Has thanked: 14363 times
Been thanked: 1661 times
DESCRIPTION
Smart Tube apk For Smart tv free Download
Smart tube You want to watch youtube on your smart android tv First of all, go to the settings of your Android TV and now check out what is its Android version. This application supports minimum Android version 4.2
How to install Stn beta
Download this application file and copy it to USB Connect USB to TV and open File Manager And where is inside the USB, where did you copy the application, find it and click on it This application will be installed on your TV In the Apps menu of the TV, an application will appear in the name of STN Beta. Date and time should be according to your region to run this application
On Search Keyboard open
Go to SmartTube setting Enter remote control and click on
[SHOW POST]
https://icedrive.net/s/yxPSiaGYuzxBhN6ySxziSfyZb9Qv
Return to “Extras”
