CiefpOpenSubtitles
CiefpOpenSubtitles
🎬 CiefpOpenSubtitles Plugin v1.1
Subtitle search & download plugin for Enigma2-based set-top boxes (OpenATV,PurE2,OpenPLi, etc.) β€” supporting OpenSubtitles.com and OpenSubtitles.org.
βœ… Key Features:
πŸ” Search subtitles for movies and TV series by title
🌐 Dual-site support:
OpenSubtitles.com (via free API key β€” recommended)
OpenSubtitles.org (via username/password login)
πŸ—£οΈ Multi-language support: enter language codes (e.g. sr,hr,en or srp,hrv,eng)
⬇️ Automatic download & save to user-defined directory
πŸ”„ Multi-language download mode β€” fetch subtitles in all configured languages for a given title
πŸ› οΈ Fully configurable via settings screen:
Save path
Download delay (to respect API rate limits)
Language priority (first match vs. all languages)
Auto-renaming to match video files (e.g. MovieName.sr.srt)
πŸ“± How to Use:
Launch the plugin from Extensions menu.
Choose "Search Movies" or "Search Series".
Press YELLOW to open the virtual keyboard and type the title.
Press GREEN to start the search.
Navigate results with arrow keys.
Press BLUE or OK to download the selected subtitle.
Subtitle is saved automatically (default: /media/hdd/subtitles/).
πŸ’‘ Note: For OpenSubtitles.com, you need a free API key
(register at https://www.opensubtitles.com).
πŸ› οΈ v1.1 β€” What’s New:
Added site selection: .com (API) vs .org (login)
Improved result sorting (by year ↓, then downloads ↓)
Multi-language download support
Auto-matching of downloaded subtitles to existing video files
UI optimized for 16:9 screens (1600Γ—800)
Enhanced text readability & MetrixHD skin compatibility
Why use CiefpOpenSubtitles?
⭐ The best series search - more accurate results than other plugins.
🌐 Support for OpenSubtitles.com (API Key) and OpenSubtitles.org (login).
🎬 Automatic mapping of subtitles to video files.
πŸ› οΈ Fully configurable - languages, path, delay, priority.
πŸ“± Ease of use - simple interface, fast search.
πŸ› οΈ Save API Key, Username and Password
In the main menu of the plugin, select API Key / Login (blue/OK).
For .com (recommended – faster and better):
Press GREEN (Edit API Key).
Enter the API key from opensubtitles.com (free account > API tab > Create new key).
It is saved automatically in the file: /etc/enigma2/ciefpopensubtitles/opensubtitles_apikey.txt
(format: apikey=xxxxxxxxxxxxxxx).
For .org (older system):
Press YELLOW (Edit Login).
Enter username, then password from opensubtitles.org.
It is saved automatically in the file: /etc/enigma2/ciefpopensubtitles/opensubtitles_login.txt
(format:
user=yourusername
pass=yourpassword).
πŸ‡¬πŸ‡§ How to get an API key (OpenSubtitles.com)
Go to https://www.opensubtitles.com
Click "Login" (or "Sign Up" if you don’t have an account)
After login, go to: Account β†’ API
Click "Generate API Token"
Copy the generated API Token (e.g. abc123xyz456)
Enter it in the plugin:
Extensions β†’ OpenSubtitles β†’ Settings β†’ API/Login β†’ API Token
πŸ” The API token is personal β€” do not share it.
..:: CiefpOpenSubtitles ::..
CiefpOpenSubtitles 1.1.rar
(2.69 KiB) Downloaded 29 times
Return to β€œPlugins”
