..:: CiefpIPTVBouquets ::..
CiefpIPTVBouquets is an Enigma2 plugin designed to manage IPTV bouquets on Enigma2 devices.
It allows users to download, install, edit and delete IPTV bouquets directly from the GitHub repository,
as well as manage channels within the bouquet. The plugin is useful for users who want to easily organize IPTV content,
including channels, series and movies, with an intuitive interface.
Main functions:
Download and install IPTV bouquets from GitHub.
Bouquet editing (selecting, moving, deleting channels).
Group selection of similar channels (e.g. "HBO 1", "HBO 2", "HBO").
Management of deleted bouquets (.del files).
Reload settings after changes.
Screens and their use
The plugin has one main screen and four additional screens, each with specific functions.
Here is a brief description and instructions for using each:
1. ..:: CiefpIPTV ::.. (Main screen)
Description: This screen allows downloading and installing IPTV bouquets from the GitHub repository.
Functions:
- Displays a list of available bouquets from GitHub (left).
- Allows selecting a bouquet for installation (right).
- Starts installation of selected bouquets and reloading settings.
- Provides access to other screens (IPTV Manager, BouquetViewer).
Usage:
- OK/Green: Selects/deselects a bouquet from the left list and adds it to the right list.
- Yellow: Starts installation of selected bouquets (confirmed by a dialog).
- Red: Opens the IPTV Manager screen.
- Blue: Opens the BouquetViewer screen.
- Cancel: Exits the plugin.
- Up/Down: Navigates through the bouquet list.
Note: Bouquets are downloaded from GitHub, so an internet connection is required.
2. ..:: BouquetViewer ::..
Description: Allows preview of the selected bouquet before installation.
Functions:
- Displaying the contents of the selected bouquet gives the user the ability to preview the selected bouquet before installation.
3. ..:: IPTV Manager ::..
Description: Allows management of installed IPTV bouquets, including deleting and editing.
Functions:
- Displays a list of installed IPTV bouquets.
- Allows selection and deletion of bouquets.
- Provides access to editing bouquets via the IPTV Editor screen.
Usage:
- OK/Green: Selects/deselects a bouquet for deletion.
- Red: Deletes the selected bouquets (confirmed by a dialog).
- Yellow: Opens the Bouquet Cleaner to delete .del files from etc/enigma2
- Blue: Opens the IPTV Editor to edit the selected bouquet.
- Cancel: Returns to the main screen.
Note: Deleting bouquets removes them from the system, and reloading settings is optional after deletion.
3. ..:: IPTV Editor ::..
Description: Allows detailed editing of channels within the selected bouquet.
Functions:
- Displays the list of channels in the bouquet.
- Supports selection, group selection of similar channels, moving and deleting channels.
- Allows saving changes and reloading settings.
Usage:
- OK: Selects/deselects an individual channel.
- Red: Deletes selected channels (confirmed by a dialog).
- Green: Saves changes in the bouquet (confirmed by a reload dialog).
- Yellow: Enables/disables "Move Mode" for moving selected channels.
- Blue: Starts group selection of similar channels (e.g. selecting "HBO 1" means "HBO", "HBO 2", etc.).
- Up/Down: Navigates through the channel list; in "Move Mode", moves selected channels.
- Left/Right: Scrolls pages; in "Move Mode", moves channels by multiple positions.
- Cancel: Exits the screen (warns if there are unsaved changes).
Note: The "Select Similar" function is optimized for recognizing similar channels (e.g. "HBO", "Cinemax", "Star Wars Episode"),
including unselecting if all similar channels are already selected.
4. ..:: Bouquet Cleaner ::..
Description: Manages deleted bouquets (files with the extension .del).
Functions:
- Displays a list of .del files in the /etc/enigma2/ directory.
- Allows selection and permanent deletion of .del files.
Usage:
- OK: Selects a single .del file.
- Green: Selects all .del files.
- Red: Deletes the selected .del files (confirmed by a dialog).
- Up/Down: Navigates through the file list.
Note: This is useful for cleaning up old or unnecessary deleted bouquets.
How to use the plugin
Installing a bouquet:
Run the plugin and wait for the bouquets to load from GitHub on the main screen.
Select the desired bouquets (OK/Green) and install them (Yellow).
Confirm reloading the settings if necessary.
Viewing bouquets:
Viewing the contents of the selected bouquet before installation
Editing a bouquet:
From the main screen, go to the IPTV Manager (Red).
Select a bouquet and open the IPTV Editor (Blue).
In the IPTV Editor, select channels (OK), group select similar channels (Blue), move them (Yellow + Up/Down), or delete them (Red).
Save changes (Green) and confirm reloading.
Deleting a bouquet:
In the IPTV Manager, select bouquets (OK/Green) and delete them (Red).
Confirm reloading the settings.
Cleaning .del files:
From the main screen, go to Bouquet Cleaner (Blue).
Select .del files (OK or Green for all) and delete them (Red).
Conclusion
CiefpIPTVBouquets is a powerful tool for managing IPTV bouquets, with a focus on simplicity and flexibility.
The main screen is for installation, IPTV Manager for managing bouquets,
IPTV Editor for detailed channel editing, and Bouquet Cleaner for cleaning deleted files.
..:: CiefpSettings ::..
CiefpIPTVBouquets
- Zaam
- Has thanked: 375 times
- Been thanked: 220 times
CiefpIPTVBouquets
- ciefpiptvbouquets-9.jpg (137.35 KiB) Viewed 381 times
- CiefpIPTVBouquets 1,7.rar
- (3.56 KiB) Downloaded 24 times
