This is a basic guide to USB flash a local image zip file to the Zgemma H9 Combo +TWIN.
User will require a USB stick formatted FAT32.
1) Download your chosen image.
2) Transfer the complete zip file to root of the USB stick. Do not unzip the file.
3) Power off the Zgemma H9 Combo and connect the USB stick front USB port behind front flap.
4) Power on the Zgemma H9 Combo, as soon as you power on HOLD DOWN reset black baten on the back
5) Once you're booted into the Multiboot recovery menu screen below select 'Bootmenu' at the bottom and press OK on the remote.
6) On the next screen select 'Flash local image' and press OK on the remote.
7) On the next screen you select the USB stick where your image zip file is located.
8) On the next screen you'll then select the zip file that's on your USB stick that you'd like to flash and press OK on the remote.
9) You'll now select which slot you'd like to flash your image to. Remember which slot you are currently booting from and have setup. Flashing to that slot
WILL REFLASH that slot, you will loose everything you have setup in that slot
. We have setup OpenViX in Slot 1, for this guide we are re-flashing OpenViX in slot 1, OpenATV 6.2 is in slot 2 and we have OpenPLi already flashed to slot 3. Select Slot 1 and press ok on the remote.
( unzip only one file _recovery_emmc.) second file dont uzip send on usb like is
How TO Flash Zgemma H 9 Combo + Twin
