E2BissKeyEditor v1.0
Has thanked: 14280 times
Been thanked: 1572 times
A new plugin in the Enigma world
The E2 BISSKEYEDITOR V1 Plugin
In the name of God, the Most Gracious, the Most Merciful,
And prayers and peace be upon the noblest of messengers.
I am pleased today to present a new work and a new service for Enigma2 enthusiasts.
The E2BissKeyEditor plugin, in its first version, will be your companion for entering BISS codes into your device.
*** Plugin Features ***
1. Enter codes in a very simple way (similar to the method used in Juasat devices).
2. Automatic correction of cells 4 and 8 of the BISS code.
3. Display detailed channel information:
SID
VPID
APID
REF
PMTPID
ONID
TSID
TP INFORMATION
4. Determine the method for building the code identifier in the SoftCam.Key file:
SID+VPID
SID+APID
SID+PMTPID
CRC32 ORIGINAL
CRC32 STANDARD
5. Automatically save codes in the code file while checking for the file in various paths.
6. Automatic restart of the emulator when saving the code.
7. Automatic clearing of cells by pressing the blue button.
The plugin has been tested on the following images:
1. OpenAtv 7.5.1, 7.6
2. OpenPli 9.1
3. Egami 11.x
4. OpenVix
5. OpenBH 5.5, 5.6
The main interface of the plugin:
· Enter codes using buttons 0-9 to insert numbers.
· Use the up/down buttons to navigate between characters A-F.
· Use the OK button to print the character.
· Use the left/right buttons to navigate between parts of the code.
Interface for selecting how to build the code identifier in the SoftCam.Key file:
· Appears by pressing the Menu button.
Information about the plugin: Info button.
E2BissKeysEditor-V1-0.tar.gz
(128.53 KiB) Downloaded 9 times
