Gemini 4.2 backup image
General discussions, images, information, tutorials, picons, skins, plugins, settings, software and tools for receivers
Has thanked: 14360 times
Gemini 4.2 Backup image
This is my first attempt to build a DreamOS backup ! I'm not a fan of DreamOS ,
I'm not a fan of moding and saving the result into a backup ! but ... some curious
events pushed me into that direction !
What was the goal ?
- to start from last DreamOS FW
- to keep things as simple as possible
- to change the default HD skin into default FHD skin
- to install Multiboot Selector Plugin
- and make a Backup from OpenATV to be easier if
some drama hapen and must be restored !
- then i found the right Oscam ( thanks levi) , installed
and found it working fine ! and from GP4-feed using Addon
Manager I found the missing item ... Camd Manager Plugin
- now I have Oscam working and controlled
- now it was the moment for another backup ... just in case !
- the final step was to install some IPTV players ... a la mode !
the chosen were AJpanel witch was boring ! installed and
started without any problem ! and PlutoTV found in the same
GP4 feed !
- PlutoTV was installed without problems ! but my country does
not have a Region PlutoTV Server so ... I've borrowed the bouchet
created in OpenATV by PlutoTV, "instaled" in DreamOS and ...
items from Favorites "plutotv_at.tv" played smoothly ! what a relief !
- now was the moment of the final backup image !!!
I must admit that the image is performing surprisingly well !
boot fast , navigate smoothly thru menu , image and sound
are outsanding ! Oscam is doing well his job ! and IPTV is better
then in OpenE2 ... so at the end , was a good day !
https://mega.nz/file/GsNGXIJK#7R8pjw0UX2lHQaJTwV4wO0LtWGBp45gwIC4g2wlUFTg
Re: Gemini 4.2 backup image
Backup Dream One image for Merlin 5 DreamOS
Based o previous experience , it took me just over one hour
to produce a equivalent Merlin Backup ! Why I've do it ?
- Merlin has a lower charge over the DeamOS FW ! the
archive is ~95 Mb compared to 130 Mb at Gemini ! that
means the image will load faster !
- Merlin include from the beggining Camd support !
https://mega.nz/file/elNwjYQT#GCDxl6DJm411EgeoGXF35F4_-03H8TOj0_IN9XskKas
Return to “Dreambox”
