[E² Plugin] IPTV Dream
IPTV Dream is a tool for quick and convenient importing of IPTV lists to your Enigma2 tuners (OpenATV, OpenPLi, etc.).
The plugin creates ready-made bouquets (favorites lists) based on your data.
Supported sources:
-MAC Portal (Stalker): Just provide the portal address and MAC – the plugin downloads the list and tokens by itself.
-Xtream Codes: Login via host, username, and password.
-M3U Files: Loading lists from .m3u files saved on the tuner's HDD/USB.
-M3U Links: Direct list downloading from a URL address.
KEY CHANGES:
Super Fast Keyboard: No more stuttering! I completely rewrote the data entry handling. Now, after selecting an option (e.g., MAC Portal), the keyboard window opens immediately, without unnecessary intermediate screens or lag. Typing is smooth and trouble-free.
Stable Playback (Black Screen Fix): We implemented fixes for Stalker/MAC servers that were blocking access. The plugin now identifies itself as a MAG250 decoder, which eliminates the "black screen" problem on most portals.
EPG Mega Pack: I added automatic installation of a rich set of EPG sources (Poland, UK, USA, Germany, Africa). The plugin generates the source file for EPG Import automatically! – Note: You must select these sources in EPG Import and download them manually.
Intelligent EPG Matching: A new algorithm ("Shotgun") generates dozens of name variants for each channel (e.g., SkySports1, sky-sports-1.uk), so EPG finally works on foreign channels!
Clean Channel Names: We automatically remove junk from channel names (like PL VIP, FHD, RAW), making the list look aesthetic and professional.
Better Updater: Fixed online update errors (no more ZIP archive error messages).
UI Fixes: Removed unnecessary prompts (e.g., about GUI restart – now the plugin only informs you what to do).
Creator: Paweł Pawełek | Version: 3.2
EPG Issues
"First, make sure that in the EPG Import plugin you have selected sources from the 'IPTV Dream' category and performed an import.
If EPG is still missing, it means the channel name from your provider differs from the name in the EPG database. The plugin automatically tries to match names, but even a single different character, space, or dot is enough for the system not to recognize the channel. In cases where the automatic tool cannot catch it, manual reference assignment using E-Channelizer or DreamboxEDIT remains the only option."
Installation: Via Panel AIO 4.3 plugin or from an .ipk file.
Installation (Telnet)
wget -q "--no-check-certificate" https://raw.githubusercontent.com/OliOl ... staller.sh -O - | /bin/sh
Thanks Paweł Pawełek
- Has thanked: 14324 times
- Been thanked: 1612 times
