CiefpSatelliteAnalyzer
Been thanked: 1668 times
**Ciefp Satellite Analyzer – Release Notes v1.5**
*(upgrade from GitHub version 1.4)*
New features and most important changes:
1. Full Abertis support
- Special screen for Abertis analysis
- Direct analysis over 37 most common Abertis PIDs
- Automatic creation/update of bouquet userbouquet.buket_abertis.tv
- Delete and view Abertis logs
2. New configurator for astra.conf (without manual editing)
- Add T2MI decap block – all via graphical interface (Green → Astra.conf → Add T2MI decap block)
- View and edit the entire astra.conf file in the plugin
- Create a blank astra.conf file with one click
- Automatic replacement of localhost → 127.0.0.1 in URLs
3. Smart log storage
- T2MI logs: t2mi_Provider_Satelit_Datum_PID.log
- Abertis logs: abertis_Provider_Satelit_Datum_PID.log
- Automatically add number if file already exists
4. Bouquet improvements
- Userbouquet.buket_t2mi.tv and userbouquet.buket_abertis.tv are created
- Automatically add a nice marker with provider, satellite and PID
- Correct encoding of URLs for Abertis
- Automatic reload of bouquet after creation
5. Better cleaning and stability
- Safely stop astra process (yellow button or exit)
- Restart streamrelay and astra-sm service after analysis
- Reset tuner and free up resources
6. Minor improvements
- Display current clock in main screen
- Better display of PLS Mode/Code and T2MI info
- Reboot system with confirmation after saving astra.conf
- Bug fixes from version 1.4
The plugin is now much easier to use – especially for anyone using T2MI and Abertis feeds on Astra-SM.
Thanks everyone for your support!
Ciefp – November 2025
..:: CiefpSettings ::..
Return to “Enigma2 Settings”
