Oscam SVN - Oscam GIT / Changelogs / Patches
Changeset 11905
-Resolve "Loadbalancer - fallback adjustment"
* Allow lb_nfb_readers to be set to zero (previously minimum was 1). This means you can configure the system to have no fallback readers if desired.
* If only one reader matches and double_check is enabled (and the CAID matches), the patch forces a fallback check by setting force_reopen = 1.
thanks to lpm11
thanks tem_invictus
- Has thanked: 14324 times
- Been thanked: 1623 times
Re: Oscam SVN - Oscam GIT / Changelogs / Patches
Changeset 11968
docs: remove unused generated HTML documentation
The HTML copies are not referenced by the build, packaging, runtime, or
project documentation. Users are directed to the wiki, text documentation,
or installed man pages instead.
Changeset 11967
Remove legacy mpcsmon monitoring utility
* cmake: remove obsolete distribution monitor install rule
* Remove Distribution monitor
Changeset 11967
- 1938 Views
Last post by dave007
- 1784 Views
- 4530 Views
- 95 Replies
- 17649 Views
Last post by VivaEuropeTV
- 11 Replies
- 9510 Views
