orient service menu code
You can get here some interesting stuff and test it before official release.
Has thanked: 14363 times
Been thanked: 1660 times
The Orient service menu code is Input 2580 or Source 2580/2588. You may need to press the Input or Source button on your remote, followed by the corresponding code, to access the service menu.
Input/Source Code: Try pressing Input or Source, and then enter the code 2580 or 2588.
Alternative codes: In some cases, a different code like Menu 2580 or Menu 2588 might work.
Check the manual: If the codes don't work, consult your specific TV model's user manual for the correct service menu access method.
Return to “Extras”
