[E² Skin] Fury_FHD
Been thanked: 1667 times
[E² Skin] Fury_FHD
New update for Fury-FHD V5.7 skin
1️⃣ Added a new screen for Secondinfobar
...containing a signal viewer
2️⃣ Updated Movie Player screen
3️⃣ Improved overlapping of some lines when increasing font size
4️⃣ Added 3 font size levels
5️⃣ Updated the skin plugin screen
6️⃣ Reduced skin size to 12 MB
7️⃣ Other improvements to enhance skin performance
»»» Supported Images «««
OpenAtv all versions
Egami all versions
Pure2 all versions
OpenVix 6.7
Openbh 5.4 @ 5.5.1
OpenPli foxbob
OpenPli Py 3.9.9 & 3.11
https://www.mediafire.com/file/vq3pvvil ... l.ipk/file
Re: [E² Skin] Fury_FHD
Fury-FHD
New Update for Fury-FHD Skin V6.0**
🔥🔥 For the first time in the Enigma2 world — EPG translation to ANY language directly on your device!
No codes, no subscription — just install the Fury Skin 🔥🔥
1️⃣ Ability to translate EPG into any language using the special plugin FuryEpg
Just open the plugin → go to settings → select your language → press save.
The event text next to the channel name will not be translated to keep posters visible.
2️⃣ Ability to save translation cache on your HDD
This prevents filling the box’s internal memory.
You must enable this the first time from inside the plugin for translation to work.
3️⃣ Ability to clear translation cache
Press the yellow button to delete it.
The cache will also auto-delete automatically when it reaches 5000 events.
4️⃣ Translations are saved automatically
So you don’t have to translate the same event again every time.
5️⃣ Additional improvements to enhance skin performance
🚫 The skin update from inside the skin has been fixed on OpenBH image
For members who had issues updating on OpenBH.
If the issue remains, please install the skin via the script or Telnet command. 🚫
OpenPLI Python 3.9.9 & 3.11
MediaFire Download Link (IPK)
enigma2-plugin-skins-fury-fhd_6.0_all
(Direct download file)
MediaFire Script Link
Fury-FHD-installer.sh
(Download the installer script)
Telnet Installation Command
opkg update && opkg install wget && wget -q "--no-check-certificate" https://raw.githubusercontent.com/islam ... staller.sh -O - | /bin/sh
The new update is also available from inside the skin plugin.
Images Support
1 OpenATV All Version
2 Egami All Version
3 PurE2 Version
4 OpenSPA Version
5 OpenBH 5.4 & 5.5.1
6 OpenViX 6.7
7 OpenDroid 7.5 & 8.0
8 OpenPli Foxbob
9 OpenPLi 9.0 & OpenPLi 9.1
10 OpenPLi Develop builds & OpenPLi Scarthgap builds
11 Corvoboys
12 TNAP
New update for the Fury knife-FHD V6.1
Addition of Persian and Ukrainian languages 1️⃣
The event next to the channel name does not translate to keep posters appearing
2️⃣ Fix the language selection screen without crush
This has to be done for the first time from the plugin for the translation to work
3️⃣ possibilities of scanning cash by pressing a button on the yellow button with the cache flag, it will be deleted automatically when you reach 5000 events
4️⃣ Translation with automatic saving means not every time you stop at the event, you will translate with the ability to save it
5️⃣ more improvements to improve knife performance
🚫 The knife has been updated from inside the knife to the Pure2 image, so that the members who are having a problem with this image in the update while the problem has not been solved, please download the knife using script or the talent issue 🚫
»»» sponsored images «««
Egami all versions
Pure2 all versions
OpenVix 6.7
Openbh 5.4 @ 5.5.1
Openpli foxbob
Media-Fire link
https://www.mediafire.com/file/9gv5mz3x ... l.ipk/file
Download script link
https://www.mediafire.com/file/wt8mwwxd ... er.sh/file
Amar your talent
Available new update 🆕 inside knife plugins
Leave any remarks in the comments with a photo.
gregor1213
E2 Developer
E2 Developer
Has thanked: 1 time
Been thanked: 16 times
Maldives
Post by gregor1213 »
Fury-FHD skin (V9.0)
1️⃣ Update to the AIFury plugin (v7.2.3)
◀️ Added new channels to the Electronic Program Guide (EPG).
◀️ Removed duplicate channels and those lacking EPG data.
◀️ Improved plugin performance for fetching events.
💥 Please wait a few seconds after installing the .ipk file to allow the AIFury plugin to complete its installation.
💥💥 Fury-FHD Skin Features
2️⃣ Added 2K resolution support for select images (firmware).
3️⃣ Updated the skin's visual style.
4️⃣ Updated several renderers (Exclusive!)
For Vu+ devices:
◀️ Updated the signal indicator renderer (fixed an issue where the AGC signal bar would not appear on certain channels).
◀️ Updated the RAM information renderer.
5️⃣ Refreshed the default 'ChannelSelection' screen for a more aesthetic look.
6️⃣ Optimized various renderers for better compatibility with lower-end hardware, resulting in a faster user experience and reduced system resource consumption.
⚡ Following this update, EPG-related data (such as subtitles/translations) will be stored in a new folder named "AIFury" on your hard drive or USB flash drive. Please update the storage path for these files within the plugin settings. ⚡⚡
🚫 The skin has been updated to support OpenATV 7.6, addressing issues some users encountered when updating on this specific image. If the problem persists, please reinstall the skin using the provided script or via a Telnet command. 🚫
🔓 All Enigma2-based images.
Telnet command 🔽
wget -q "--no-check-certificate" https://raw.githubusercontent.com/islam ... staller.sh -O - | / Bin / Sh
The new update 🆕 is available within the skin plugin.
Return to “Skins”
