[E² Plugin] Panel AIO
Been thanked: 1667 times
AIO Panel v1.6
✅ Automatic installation of missing dependencies:
The check_dependencies function now attempts to install curl automatically if it’s missing from the system.
➡️ This helps avoid errors during diagnostics and plugin installation.
✅ Improved server communication:
curl commands now include a detailed User-Agent header:
PanelAIO/Version (Python version)
✅ New function in "oscam.dbvbapi-manage":
Added option: "Clear content of oscam.dvbapi file"
✅ Updated Picons download link in the "Tools and Add-ons" section.
✅ Oscam from Feed (Auto):
Automatically detects and installs the best available Oscam version (master ➡️ emu ➡️ stable).
✅ Improved English translation when switching language in the plugin.
1️⃣ Install a clean system (e.g. OpenPLi / OpenATV) and perform the basic setup.
2️⃣ Install Panel AIO 1.6 and restart the receiver.
3️⃣ Launch Panel AIO 1.6 from the plugin menu.
4️⃣ Install your preferred channel list.
5️⃣ Install Softcam Feed.
6️⃣ Install Oscam from Feed (Auto).
7️⃣ DownLoad Picons.
8️⃣ Press the yellow button on your remote – Restart GUI.
🟢 After the restart, you can:
Use all installed tools
Clear the content of oscam.dvbapi
Update the satellites.xml file
Install other plugins via Panel AIO
…and much more!
Thanks Pawel Pawelek
Re: [E² Plugin] Panel AIO
Panel AIO 4.4
Release Notes v4.4
The new version of AIO Panel (v4.4) is here! This update focuses primarily on stability and introduces a highly anticipated memory management feature.
What's new?
NEW: Auto RAM Cleaner
You will find a new option in the Diagnostics menu. It allows you to enable automatic background RAM clearing (with interval settings, e.g., every 10, 30, 60 minutes).
How does it work? The function uses the system's drop_caches mechanism. It is a safe clearing of buffers and cache that does NOT close any running processes. It simply frees up unused resources.
CRITICAL FIX: Installation Stability
No more "spinners" or receiver freezes when installing external plugins! We fixed the issue with GUI restarts after installing add-ons like EPG Import or NCam. The restart process is now smooth and safe.
Other changes:
[-] Fixed the "invalid syntax" error on startup.
[-] Optimized installation scripts (faster execution).
[-] Removed redundant system scripts.
How to update?
Go to: Info & Diagnostics -> Plugin Update. Restart GUI after update.
[SHOW POST]
https://satworld-forum.com/index.php?th ... l-aio.244/
