Version 1.1.5
Added oscam status reader display screen and ecm.info display screen
Translations have been completely reworked with the help of a.i. check if the translations are suitable for your language
This was the hardest part of the job to get the reader display
Error after error, there is nothing I haven't tried more, there came a moment when I thought I would give up on this option.
But I still didn't give up, it was hard but I managed in the end, there is room for improvement.
I also plan to add more to the processing of oscan.conf and oscam.user files.
..:: Ciefp Oscam editor 1.1.5 ::..
display ecm info
- channel
- service id
- caid
- caid(Active)
- ecm pid
- provider
- chid
- reader
- from
- protocol
- hops
- ecm time
red button - exit
green button - Add dvbapi - opens screen - Add dvbapi line
yellow button - settings - opens screen - Settings
blue button - oscam.server - opens screen - View oscam.server
..:: Ciefp Oscam Editor Settings ::..
DVBAPI path:
default - etc/tuxbox/config/oscam.dvbapi
osccam-emu - etc/tuxbox/config/osccam-emu/oscam.dvbapi
oscam-master - etc/tuxbox/config/osccam-master/oscam.dvbapi
oscam-smod - etc/tuxbox/config/osccam-smod/oscam.dvbapi
oscamicamnew - /etc/tuxbox/config/oscamicamnew/oscam.dvbapi
Language:
("en", "English"),
("sr", "Srpski"),
("el", "Greek"),
("ar", "Arabic"),
("de", "German"),
("sk", "Slovak"),
("pl", "Polish"),
("tr", "Turkish")
Automatic version detection - Yes,No
Webif IP: - 127.0.0.1
Webif user:
Webif password:
Refresh interval: 5 seconds,10 seconds,30 seconds,60 seconds
if you have a user and password set in oscam.conf
then enter the user and password data
if you do not have a user and password field in oscam.conf
in that case leave the user and password field empty
..:: Add dvbapi line ::..
show multiple text input tables:
- Priority [P:] caid:provider:sid
- Ignore [I:] caid:provider:sid
- Merge [J:] caid1:provider1:sid:ecmpid caid2:provider2:ecmpid2
- Map [M:] caid:eek:ldprovider:sid caid2:newprovider:sid2
- Add [A:] ns:sid:ecmpid:caid:provider:
red button - cancel
green button - Add - adds the entered line to oscam.dvbapi
yellow button - Preview - opens the screen - Preview oscam.dvbapi
blue button - oscam_info - opens the screen - OSCam Info
..:: Preview oscam.dvbapi ::..
- display the contents of the oscam.dvbapi file
red button - exit
green button - Save
blue button - Delete - deletes the line from oscam.dvbapi
..:: oscam_info ::..
- display oscam.version file
red button - exit
green button - Status
..:: OSCam Status ::..
- display all readers - reader:status:au:idle time:protocol
red button - Exit
green button - Refresh - here you can manually refresh the status
yellow button - ECM Info - opens the ECM Info screen
..:: ECM Info ::..
- display the ecm.info file - etc/tmp/ecm.info
red button - Exit
..:: View oscam.server ::..
- display the contents of the oscam.server file
red button - exit
green button - Free CCCam
yellow button - Add reader - opens the screen - Add reader
blue button - Delete - opens the screen - Select reader
..:: Free CCCam ::..
Select source
1.CCCamia Free
2.CCcam Premium
3.CCcamIPTV Free
..:: Add reader ::..
- display the data entry tables oscam.server
red button - cancel
green button - Save
..:: Select reader ::..
- display reader name from oscam.server file
by selecting deletes all lines related to selected reader
The entire reader is deleted.
red button - delete
green button - Save
..:: CiefpSettings ::..
CiefpOscamEditor
- Has thanked: 14324 times
- Been thanked: 1612 times
CiefpOscamEditor
