IPTV FREEZ
hugo sanchez
Has thanked: 1 time
Been thanked: 1 time
Anguilla
IPTV FREEZ
Post by hugo sanchez »
Good morning, returning to the blocks on iptv lists, I switched to fiber, I put the VPN and now I have entered FIXED IP, but things DO NOT CHANGE.... can you help me understand where to intervene. Thank you very much. :tdf
Has thanked: 14281 times
Been thanked: 1572 times
Re: IPTV FREEZ
There are several issues with CGNAT and IPTV:
The IPTV provider might see too many connections from the same public IPv4 and think your account is being shared or they abusing their system and block access
Your public IPv4 can change regularly over CGNAT so your IPTV provider might think your account is being shared and block access
The public IPv4 addresses the CGNAT service uses might not be marked as belonging to a consumer ISP so your IPTV provider might not allow them
The public IPv4 addresses the CGNAT service uses might not be correctly set as based to the UK in the GeoLocation service your IPTV provider uses to they might not allow them
hugo sanchez
Has thanked: 1 time
Anguilla
Re: IPTV FREEZ
Thanks......too complicated for me......
Return to “IPTV Free m3u Playlists”
