tiger t3000 mega stuck on boot
Malik3431
Has thanked: 77 times
Been thanked: 107 times
Post by Malik3431 »
Dear experts .
my receiver stuck on boot loop
try to make reset but in-vain does not install soft ware update
and booting just stuck on boot menu
help required.
ZGEmMA H7sSR-90000 eXtreme
Has thanked: 14363 times
Been thanked: 1660 times
Re: tiger t3000mega
upgrade it with PC with hiTool,
put the USB using software with " Romupdate.bin ".
Malik3431
Re: tiger t3000mega
Post by Malik3431 »
The Founder wrote: ↑05 May 2025, 14:28 upgrade it with PC with hiTool,
please some details
thanks.
Re: tiger t3000 mega stuck on boot
How To Solve Tiger T3000 Mega 4K Receiver Boot Problem Solution? Tiger T3000 Mega 4K Stuck On Boot.
Reasons Behind the Boot Stuck Problem In Tiger T3000 Mega Receiver?
Power failure
Using wrong or incompatible software
if you did any mistake or upgrade the wrong Software or cut the power during the installation of the Software if Your Tiger T3000 Mega Receiver is stuck on Boot then how you will recover it, I’m the admin of Receiver Pro and you are reading this post on Receiver Pro, So follow me for the boot problem solution of your Receiver.
Step1.
First of all Download the below-given software from the link below then formats your USB flash drive with the NTFS or FAT32 Format system. please use the virus-free USB flash drive, otherwise, the process will disturb. after completing the format Process of your USB flash.
Step2.
Create a Folder inside your USB Drive Root area. folder Name Shall be RomUpdate. the file that you downloaded from the link below is named RomUpdate. Now You Cut and paste the RomUpdate file into your USB flash drive.
BOOT PROBLEM SOLUTIOS BOOT PROBLEM SOLUTIOS
Step2.
Now turn off the Receiver and turn it on again, after turning on the receiver again, Press and hold the power button on the front panel of the Receiver or you can also use the remote control Power Button. Please Keep Pressing until you don’t see the Upgrade Option On the Receiver LCD Screen.
when you see the Upgrade Option On the Receiver LCD Screen, Wait for a few seconds for the update to start and remove your hand from the power button. Once the recovery process is completed. The receiver will reboot itself and come to normal functions.
after completing the installation process your box may take 4 to 5 minutes time for a reboot, so you have to wait. Now remove your USB flash drive, your Receiver is Now recovered successfully. see in
TIGER T3000 EXTRA 4K ROMUPDATE FILE
https://www.mediafire.com/file/stw5fblarvxs2r4/RomUpdate.bin/file
Return to “Others STB”
