[E² Plugin] Screen Recorder
pavelparal
Been thanked: 30 times
Czech Republic
Post by pavelparal »
Screen Recorder v1.0
@Emil Nabil Ragheb
Easily record and share your moments
you can record your screen in high quality with ease, whether you need to record a demonstration video or a live capture of your device!
Why do you need this Plugin?
Ease of use: A simple interface that lets you start and stop recording with the push of a button.
Advanced settings: Precise control over quality, resolution, frame rate, and encoding type to ensure the best performance for your needs.
Two recording modes: Choose between normal or demonstration recording according to your preference.
Instantly stop recording: With a single press of a button, you can stop recording effortlessly.
Smart file management: Recordings are automatically saved in the location you specify, and quality can be adjusted to save space.
Smart alerts: Automatic notifications when space is running low or when FFmpeg is unavailable.
How does it work?
Start normal recording: Press the green button to immediately start recording in clear quality.
Start demo recording: Press the blue button if you want to record a video tutorial.
Stop recording: Press the red button to end the recording and save it automatically.
Advanced Settings: Press the Menu button to adjust the video quality, frame rate, or save location.
What makes it special?
Compatible with all Enigma2 devices.
Supports resolutions up to 1280×720 with the ability to adjust the frame rate.
Supports FFmpeg to ensure high-quality recording.
Easily manage your recordings without the need for any technical expertise.
Important notes
Plugin is designed to be simple and easy to use.
It does not record the sound or image of the channel, to make it easier to explain and teach.
You can add audio or text to the video.
enigma2-plugin-extensions-screenrecorder_1.0_all.ipk.zip
(72.83 KiB) Downloaded 65 times
