[E² Plugin] Smart Addons Panel
Has thanked: 14363 times
Been thanked: 1661 times
Smart Addons panel​
Emil Nabil Ragheb wrote
*Discover a new world of add-ons with
**Smart Addons Panel**
Looking for a comprehensive platform to manage your set-top box addons easily and professionally?
is the perfect solution for you! This panel is designed to offer you a unique experience in installing plugins, themes, images, and system tools at the click of a button, with a sleek and smooth user interface that suits all users.
### **Why Smart Addons Panel?
- **Intuitive interface**: An organized visual layout that displays key sections such as **Panels**, **Plugins**, **Media**, **Emu**, **Skins**, and more, making it easy to find any tool or add-on you need.
- **Huge variety**: More than **20 sections** with hundreds of updated add-ons, from system tools like **Curl** and **Wget**, to custom themes, channel menus, and even **Multiboot** add-ons.
- **Bulk Install**: Choose multiple add-ons at once and watch as the installation process is automated with an interactive progress screen.
- **System Vital Information**: Instantly know the status of your device by displaying details such as **IP address**, **Python version**, **image type**, **Memory usage**, **Internet connection status**.
- **Auto-update**: Plugin notifies you of new versions and you can install them directly without leaving the interface.
### **How does it work?
1. **Browse the sections**: Navigate through the main menus using the directional buttons, and select a section such as **“Panels”** or **“Skins”**.
2. **Choose your add-on**: A submenu will appear with all available options. Press **OK** to add it to the installation list.
3. **One-Click Install**: After selecting the add-ons, press the **Green Button** to start the installation. Plugin will show a detailed progress screen until the process is complete.
4. **Enjoy Updates**: Press the **Yellow Button** to check for updates, or the **Blue Button** to immediately restart Enigma2.
### **User Tips**
- **Try premium themes**: **Aglare-FHD** or **XDreamy-FHD** for a stunning visual interface.
- **Use system tools**: Like **FORMAT_HDD_TO-Ext4** to optimize storage space, or **Fix Softcam** to fix CAM issues.
- **Keep backups**: Use the **Backup/Restore Settings** sections to save your important settings.
### **How to install the Plugin?
1. Copy the telnet command and paste it into your telnet or DCC program
2. Restart Enigma2, and you will find the Plugin in the Add-ons menu under
**Smart Addons Panel**.
wget https://raw.githubusercontent.com/emilnabil/download-plugins/refs/heads/main/SmartAddonspanel/smart-Panel.sh -O - | /bin/sh
It's not just a tool... It's a gateway to a world of possibilities! Whether you're a casual user or a professional, you'll find everything you need to optimize your device experience
