ALI 3510C HW102.02.008 NEW SOFTWARE WITH DOLBY AUDIO
Has thanked: 14325 times
Been thanked: 1629 times
This time what we are
discussing is the new ali3510c software with hardware version code ALI 3510C
HW102.02.008. There are many receivers with the ALI 3510C chipset with the hardware
code ALI 3510C HW102.02.008. Usually what differentiates between receiver
series with the same HW is the remote configuration. So even though the HW code
is the same, it doesn’t necessarily mean the remote is the same, so many
provide universal or multi-remotes
Latest Guoxin GX6605S ALI
3510C HW102.02.008 Receiver Software
In Asia itself, there
are many satellite dish receivers that have the ALI3510C chipset with the
hardware code ALI 3510C HW102.02.008. However, usually, if the receiver
firmware is not specific to the Indonesian region then it doesn’t support the
remote. It can be seen from the list of receivers with the ali3510c chipset
which is identical to the Matrix Burger S1 mini that the Receiver option once posted.
If anyone really needs a
download link for the ALI3510C software with ALI 3510C HW102.02.008, the Receiver option will add the information on this page. For those who want to upgrade the ALI 3510C HW102.02.008 decoder software, be careful, please check the
firmware first to avoid various problems caused by corruption. For those in
Asia, don’t forget to prepare a multi-remote.
What’s new in this new software?
Dolby Digital Plus or EAC3 Audio ok
MGCAM was added for Mgcam lovers and works well
Added USB 3G option, with the help of this 3G option you can connect your internet through a 3G 4G device.
https://www.mediafire.com/file/x4ups6oqki3zeel/ALI3510C+HW102.02.008+May+2021.abs/file
Return to “Others STB”
