CiefpBouquetUpdater
CiefpBouquetUpdater
CiefpBouquetUpdater 1.1 py3
is intended for updating bouquets on Enigma2 devices (satellite receivers).
Here's what he does:
The idea is that you will only be able to upload a certain bouquet or more.
For example, you want to update only iptv bouquets plus a few more, say on astra,
now it will be possible to do it without deleting the whole list.
Update only the bouquets you have selected.
Download and update the bouquet:
It uses the GitHub API to download the latest ZIP files with bouquet settings from a specific GitHub repository.
Automatically downloads and unpacks the ZIP file, and updates channel lists (bouquets.tv).
Presentation and selection of bouquets:
It shows the list of available bouquets with the possibility of selecting the desired ones.
Enables copying of selected bouquets to a temporary directory.
Bouquet installation:
Installs selected bouquets and shared files (like satellites.xml and lamedb) into the appropriate directories on the device (/etc/enigma2 and /etc/tuxbox).
After installation, it reloads the list of services and bouquets so that the new changes are active.
User interface and navigation:
It has a graphical interface with bouquet lists, copy, install and exit buttons.
Controls include list navigation, installation confirmation, and bouquet version display.
Essentially, this plugin automates the process of downloading, selecting, copying and installing bouquets for Enigma2 satellite receivers,
making channel updates easier for users.
..:: ciefpsettings ::..
thx ciefp
CiefpBouquetUpdater.rar
(1.6 KiB) Downloaded 92 times
Re: CiefpBouquetUpdater
CiefpBouquetUpdater Plugin (v1.3)
What does the plugin do?
CiefpBouquetUpdater enables easy download and update of channel bouquets from GitHub (ciefp-E2-75E-34W).
Users can choose which bouquets they want to install — satellite, themed or IPTV — without losing their existing settings.
How is it used?
1. Start the plugin from the Enigma2 receiver menu.
2. On the left list, choose the bouquets you want (move the arrow up/down, confirm with "OK").
3. Press the green button ("Copy") for temporary copying or the yellow button ("Install") for installation.
4. Wait for the installation to finish — the receiver will automatically refresh.
What's special?
• Selective installation: Install only the bouquets you want, not the entire list.
• Preserves user bouquets: Your personal bouquets remain intact — old files are only deleted if they overlap with newly selected bouquets.
• Name display: Instead of technical file names, you see the actual names of the bouquets (eg "•• 16.0 E - Max TV ••") according to the order from bouquets.tv.
• Quick and easy: Ideal for all users, from beginners to advanced users.
Who is it intended for?
This plugin is perfect for those who want the flexibility to update specific channel bouquets while keeping their custom lists on Enigma2 receivers.
thx ciefp
CiefpBouquetUpdater 1.3.rar
(1.54 KiB) Downloaded 79 times
Return to “Enigma2 Settings”
