OpenSPA Images download
OpenSPA 8.4.004
What is new
- New drivers :
Gigablue UHD Quad 4K PRO.
test driver for Quadpip
- Update tailscale to 1.80.0
- Update rclone to 1.69.0
- BlackSPA : add new screens.
- Improve compatibility skin openSPA_JRLG.
- Update plugin Chromium2 (working Netflix)
- Fix Foreca for Meteo plugin (spzWeather)
- Fix Aemet bug that caused crash when changing day for Meteo plugin (spzWeather)
- Fix text codification bug for OpenSPA Downloads.
- Fix OSCam Info.
- Add active CAMD info in extensions menu, into menu Decode and parental control.
- Fix and add configurable options for 12 digits display for Lunix3 4K.
- Fix texts for display 220 menu summary.
- Fix bug with network adapters.
- Subtitles: Add configurable colors (add green, cyan and magenta).
- Tuners: Add LNB unicable Inverto IDLU-32L412-UNBRR-OPN.
- Add missed screens for AutoBouquetsMaker in OpenStarHD.
- Changes in display resolution and picons codification for IPTV channels (plugin IPTVChannels).
- Fix issue with repeated bars ("/") at the end of default path /usr/share/enigma2/picon// in Picons folder, into Setting OSD menu. If anybody have this issue, change path with left or right buttons and set again your path.
To report bugs :
http://openspa.info/forums/reportes-de- ... enspa.265/
User : root
Pass : openspa
Return to “Image's”
