Welcome to VSkins 1080 (V2.23) **last updated 08/02/2025
V Skins v2.23
Fixed invalid colour reference in virtual keyboard.
Updated posts above to reflect the new KiddaC Skin Essentials plugin for toppicks and movie planner mod.
Install first for all my skins - only needs installing once
enigma2-plugin-skincomponents-kiddac-shared-skin_1.14_all.ipk
Main skin file
enigma2-plugin-skins-vskin-1080_2.23.20250208_all.ipk
Vskin 1080 (plum)
Optional Installs - see separate instructions posts below
Top Picks Mod and Movie Planner Mod has now been moved into new plugin - KiddaCs Skin E2sentials.
KiddaC Skin E2sentials
This skin will only work on newer builds due to the new botton codes being used.
Compatibility:
This skin will work on the majority of OE Aliiance builds (OpenATV 6.3, OpenVix, ItaltSat, openbh etc. Not OpenPli or Blackhole) and the majority of modern enigma2 boxes (ZGemmas - openatv, XTrends, VUs, Mut@nts, Edisons, dinobots etc.)
Installing the skin:
FTP the IPK file over to your temp folder. var/volatile/tmp.
OpenATV install instructions
Menu... setup... software management... install local extension
memory/tmp
Press ok on the package
press green to install.
Once it has installed you need to set it as your skin.
Menu… setup… Usage & GUI… skin setup
Reboot your box if you are not prompted to.
OpenVix install instructions
Menu > setup > VIX > Ipkg install
memory/tmp
Menu… setup… System… user interface… skin setup
Vskins 1080
Vskins 1080
- enigma2-plugin-skins-vskin-1080_2.23.20250208_all.ipk
- (954.6 KiB) Downloaded 126 times
- enigma2-plugin-skincomponents-kiddac-shared-skin_1.14_all.ipk
- (9.58 KiB) Downloaded 122 times
