CiefpSettingsStreamrelay PY2 1.1
The plugin is enigma2 python2 version
The plugin was made specifically for my settings and will not work with settings from other authors
The plugin loads predefined bouquets and converts them into predefined streamrelay bouquets
Satellites supported by 28.2E Sky UK and 19.2E Sky DE
How to use:
1.run the plugin
2.select bouquets
yellow button - Astra 19.2E
blue button - Astra 28.2E
it is possible to select both bouquets
status bar shows what is selected
3.Start conversion
the conversion process starts after completion
restart enigma2
..:: ciefpsettings ::..
thx chiefp
- Been thanked: 2735 times
- CiefpSettingsStreamrelayPY2.rar
- (819 Bytes) Downloaded 173 times
