firmware for Redline HD
razka
Global Moderator
Global Moderator
Been thanked: 174 times
Azerbaijan
Post by razka »
firmware Redline TG 40 HD V1.0.63 FreeIPTV YouTube
Downland
firmware Redline TG 140 HD V1.0.63 FreeIPTV YouTube
Downland
firmware Redline G 50 HD V1.0.63 FreeIPTV YouTube
Downland
razka
Global Moderator
Global Moderator
Azerbaijan
Post by razka »
Firmware Redline G50 HD V13.08 IPTV YouTube
there is a Redline G50 HD chipset AVL 1506HV main TU50 V0.1 in appearance, it does not differ from the original or brother Redline G50 HD chipset GX6605S main TGX40 V2.01, how to distinguish which AVL 1506HV which GX6605S yes it is easy, the case of AVL 1506HV is screwed from the hexagon. but there is no GX6605S, or AVL 1506HV does not have side rivets on the cover box. This is the firmware for the Redline G50 HD AVL 1506HV main TU50 V0.1 chipset
To turn on the emulator, press the remote control buttons like this - Menu -> Upgrade -> OK -> 6969 -> Super Setting -> OK.
For direct input of Biss keys, you need to stand on the encrypted channel and press the Info button on the remote control 2 times
downland
razka
Global Moderator
Global Moderator
Azerbaijan
Re: firmware for Redline HD
Post by razka »
27.05.2023
firmware Redline G50 HD V16.16 IPTV YouTube
downloand
firmware Redline S50 HD V16.15 IPTV YouTube
downloand
firmware Redline S55 HD V16.15 IPTV YouTube
downloand
razka
Global Moderator
Global Moderator
Azerbaijan
Post by razka »
firmware REDLINE S55 HD V24.97 IPTV YouTube
[SHOW POST]
download
Return to “Others STB”
