CiefpSettingsT2miAbertis​
CiefpSettings T2mi Abertis Plugin
This plugin is intended for easy installation of the necessary configurations and scripts for using T2MI Abertis functionality on Enigma2 devices.
What does the plugin do?
- Automatically checks system compatibility (Python 3 and ARM processor).
- Installs **Astra-SM** via `opkg`.
- Downloads and places configuration files:
- **astra.conf** in `/etc/astra/`.
- **abertis** script in `/etc/astra/scripts/`.
- **softcam.key** in two locations: `/etc/tuxbox/config/` and `/etc/tuxbox/config/oscam-emu/`.
- **sysctl.conf** in `/etc/`.
- At the end of the installation, it displays an overview of the installed files and suggests a system reboot.
Installation successful! Installed files:
- astra-sm
- astra.conf
- abertis
- softcam.key (/etc/tuxbox/config/)
- softcam.key (/etc/tuxbox/config/oscam-emu/)
Installation complete. Please reboot your system.
Why use this plugin?
Automatic installation and configuration without the need for manual intervention.
Quick and easy provisioning of support for Abertis and T2MI services.
Note:
This version only supports ARM processors and is intended for devices using Python 3.
installation is done via telnet with the wget command
thx ciefp
.::ciefpsettings::.
Re: CiefpSettingsT2miAbertis​
Changes to the plugin: due to problems with downloading files from github.
I rebuilt the complete plugin and now all the files are in the directory inside the plugin.
The only file that is downloaded from outside is astra-sm.
Try it and let me know the results.
thx chiefp
CiefpSettingsT2miAbertis.rar
(1.22 KiB) Downloaded 84 times
CiefpSettings T2mi Abertis Plugin v1.6
Nadogradnja postojećeg plugina,prilagođavanje novijim verzijama imidža.
Plugin bi trebao da radi na većini imidža.
Za openpli ne koristite ovaj plugin,postoji druga verzija baš za openpli.
Prilagođavanje plugina za egami imidž plugin i dalje prijavljuje grešku na update feeda
ali instalacija bi trebala da prođe uspešno.
Upgrading the existing plugin, adapting it to newer versions of the image.
The plugin should work on most images.
Do not use this plugin for openpli, there is another version just for openpli.
Customizing the plugin for the egami image plugin still reports an error on the update feed,
but the installation should be successful.
(1.23 KiB) Downloaded 73 times
Return to “Enigma2 Settings”
