CiefpsettingsMotor v1.6
python3
The plugin downloads the motor settings directly from github and inserts it into the receiver.
Plugin skida motornu listu direktno sa github i ubacuje je u risiver.
Link za instalaciju preko telneta se nalazi u fajlu
The link for installation via telnet is in the file
thx ciefp
CiefpsettingsMotor Plugin.rar
(367 Bytes) Downloaded 100 times
Re: CiefpsettingsMotor v1.6
Download and install Ciefp settings from GitHub
CiefpSettingsDownloader v1.1 py3
Plugin je namejen za instalaciju više verzija mojih listi sa Github
Pokrenete plugina izaberete želejenu verziju sačekate par sekundi
ako izađe poruka :
Reload successful! New settings are now active. .::ciefpsettings::.
Instalacija je završena i nije potreabn restart
The plugin is intended for installing multiple versions of my settings from Github
Start the plugin, select the desired version and wait a few seconds
if the message appears:
The installation is complete and no restart is required
instalacija se vrši preko telneta sa wget komandom
installation is done via telnet with the wget command
ciefp-E2-1sat-19E
ciefp-E2-2satA-19E-13E
ciefp-E2-2satB-19E-16E
ciefp-E2-3satA-9E-10E-13E
ciefp-E2-3satB-19E-16E-13E
ciefp-E2-4satA-28E-19E-13E-30W
ciefp-E2-4satB-19E-16E-13E-0.8W
ciefp-E2-5sat-19E-16E-13E-1.9E-0.8W
ciefp-E2-6sat-23E-19E-16E-13E-1.9E-0.8W
ciefp-E2-7sat-23E-19E-16E-13E-4.8E-1.9E-0.8W
ciefp-E2-8sat-28E-23E-19E-16E-13E-4.8E-1.9E-0.8W
ciefp-E2-9sat-28E-23E-19E-16E-13E-9E-1.9E-0.8W-5W
ciefp-E2-10sat-39E-28E-23E-19E-16E-13E-9E-4.8E-1.9E-0.8W
ciefp-E2-13sat-42E-39E-28E-23E-19E-16E-13E-9E-7E-4.8E-1.9E-0.8w-5w
ciefp-E2-16sat-42E-39E-28E-26E-23E-19E-16E-13E-10E-9E-7E-4.8E-1.9E-0.8w-4W-5w
ciefp-E2-18sat-42E-39E-36E-33E-28E-26E-23E-19E-16E-13E-10E-9E-7E-4.8E-1.9E-0.8w-4W-5w
ciefp-E2-75E-34W
thx ciefp
# Plugin: CiefpSettingsDownloader
# Description:
# CiefpSettingsDownloader provides Enigma2 receiver users with a fast and easy way to
# download, install, and update satellite channel lists (settings) that are carefully
# prepared and regularly updated by the CiefpSettings community.
# The plugin downloads and installs satellite lists directly from a GitHub repository,
# automatically places them in the correct locations on the device, and ensures their proper
# activation without the need for manual intervention. It also supports an automatic update
# option to ensure the plugin is always running the latest version.
# Purpose:
# The plugin is intended for Enigma2 device users who want:
# 1. Easy access to up-to-date channel lists – Downloading the latest satellite settings
# for various satellite configurations, such as motorized setups or multi-satellite antennas.
# 2. Automated installation – The plugin automatically installs the lists on the correct
# locations on the device and activates them.
# 3. Customization – Users can choose specific lists they want to install depending on
# their antenna and preferences.
# 4. Stress-free updating – The automatic plugin update option ensures the user always
# has access to the latest features and bug fixes.
# Key Features:
# 1. Downloading satellite lists from the CiefpSettings community GitHub repository.
# 2. Automatic installation of downloaded lists onto the device.
# 3. Quick activation of lists using a service refresh function.
# 4. Automatic checking and updating of the plugin to the latest version.
# 5. Simple interface – Intuitive menu for navigation, selection, and downloading lists.
# 6. Compatibility with multiple Enigma2 device types – Compatible with both Python2 and Python3 versions.
# Use Cases:
# - For home users: Ideal for users who regularly update their satellite lists
# to keep track of channel schedule changes or transponder configurations.
# - For technicians and installers: A quick way to set up the correct channel lists
# on multiple Enigma2 devices.
# - For users with motorized antennas: Downloading and installing motorized settings
# covering a wide range of satellite positions.
# Advantages:
# - Saves time: The automatic installation eliminates the need for manual downloading and
# file placement.
# - Intuitive user experience: All operations are available through a simple interface on your TV screen.
# - Regular updates: Always have access to the latest channel list versions.
# - Compatibility: The plugin automatically detects the system (Python2/Python3) and installs the necessary dependencies.
wget -q --no-check-certificate https://raw.githubusercontent.com/ciefp ... staller.sh -O - | /bin/sh
ciefp-E2-1sat-19E
ciefp-E2-75E-34W
.:: ciefpsettings ::.
CiefpSettingsDownloader.rar
(2.53 KiB) Downloaded 118 times
This plugin for the Enigma2 platform allows users to download, unpack and install the "ciefpsettings" engine from GitHub on their device.
Here's a quick overview of the functionality:
Download files: Plugin links to GitHub repository (repository is specific to "ciefpsettings-enigma2-zipped")
and retrieves the list of available settings, filtering them by static names (such as "ciefp-E2-75E-34W").
Display of files: The screen displays a list of files from GitHub, among which the user can choose one that he wants to download and install.
Installation of files: After the user selects a file, the plugin downloads the corresponding ZIP file, unpacks it,
and copies the appropriate files to the necessary directories on the device (such as /etc/enigma2/ and /etc/tuxbox/).
Reload Enigma2 settings: Upon completion of the installation, the plugin tries to refresh the service list and bouquets, so that the new settings become active.
Status display: The user is informed about the download and installation status through status messages on the screen.
This plugin makes it easy to install and update settings on Enigma2 devices,
making it a useful tool for users who want to easily update or change their settings for satellite channels, lists and other configurations.
CiefpsettingsEngine py3 1.7
(1.41 KiB) Downloaded 83 times
CiefpsettingsMotor 1.9​
Dodana podrška za py2 imidže
Added support for py2 images
(1.45 KiB) Downloaded 94 times
New version installation link is the same
thx chiefp
CiefpSettingsMotor Plugin (v2.1)
What does the plugin do?
CiefpSettingsMotor is a simple tool that downloads, unpacks and installs the latest channel list for motorized satellite dishes
directly from GitHub (ciefp-E2-75E-34W). This list includes satellite bouquets (eg 19.2E, 16.0E, 13.0E...),
thematic bouquets (sport, movies, music), IPTV channels and markers, adapted for a wide range of satellite positions.
How is it used?
1. Start the plugin from the Enigma2 receiver menu.
2. Press "OK" on the remote control.
3. Wait for the list to download and install — the process is automatic and only takes a few moments.
4. After installation, the receiver will automatically refresh and the new list will be active.
What's new in version 2.1?
• Saves user bouquets: Your personally created bouquets (eg userbouquet.moje_favorite.tv) will not be deleted.
The plugin keeps them and places them at the end of the list in bouquets.tv, while new satellite, thematic and IPTV bouquets are added to the top.
• Complete installation: All files from the list (lamedb, .tv, .radio) are copied to /etc/enigma2/,
and satellites.xml in /etc/tuxbox/, ensuring full up-to-dateness.
• Simplicity: No complicated settings — everything works with one click.
Who is it intended for?
This plugin is ideal for users with motorized antennas who want an updated channel list without losing their custom settings.
Whether you are a beginner or an experienced user, installation is quick and easy.
thx ciefp
CiefpsettingsMotor Plugin 2.1.rar
(1.73 KiB) Downloaded 100 times
Return to “Enigma2 Settings”
