Update ...
Ncam V15.2
Add Fallback reader to CCcam.cfg option
Irdeto and nagra cak7 with seca/nagra card bugs fix
* Fix 'get_emm_type() returns error' on CAK7 Seca/Nagra card
* Fix some ECM error messages don't display properly
signing: build warning when using elliptic curve signature algorithms with...
signing: build warning when using elliptic curve signature algorithms with OpenSSL versions before 1.0.0
* pipeline: use rsa signature algorithm for ancient toolchain
FreeBSD support (thanks to @khimtiki)
* Makefile, CMakeLists.txt, config.sh: use gdate + gnustat + gsplit as alternatives if available (coreutils package in FreeBSD)
* config.sh: fix 'xargs: unterminated quote' and 'Bad substitution' errors in sh shells
* globals.h: do not include sysmacros.h for FreeBSD
* oscam-signing.h: adjust trust store location + filename by operating system
Add EMM filters on Seca/Nagra card
Add support Tongfang EMM
* Add support Tongfang EMM
webif: Create default webserver SSL certificate
* when webif configured to use https and no certificate file is present
* X.509 ECDSA certificates with V3 extensions are created by default (RSA certificates for OpenSSL versions before 1.1.0)
* new option https_auto_create_cert (default = enabled)
* show OpenSSL version in startlog when webif started in https mode
* detect target OpenSSL version and show it in build log (next to compiler version)
webif: Fix default webserver SSL certificate
* disable function when OpenSSL was build without support for elliptic curve cryptography (no-ec)
* fix typo in https_auto_create_cert variable configuration
streamrelay: Fix incomplete log messages
as s_client struct information was not properly initialized
* gbox: Suppress the "failed init" log message if this module is not configured
ncam-images-ipk
https://www.satsupreme-forum.com/index. ... -zip.2256/
ncam-images-osdreambox-deb
https://www.satsupreme-forum.com/index. ... -zip.2257/
Ncam V15.2
Re: Ncam V15.2
Add New Ncam: Version 15.2
Patched and Build by MOHAMED_OS
enigma2-plugin-softcams-supcam-ncam_15.2-r0_all
enigma2-plugin-softcams-powercam-ncam_15.2-r0_all
enigma2-plugin-softcams-gosatplus-ncam_15.2-r0_all
enigma2-plugin-softcams-ultracam-ncam_15.2-r0_all
- enigma2-plugin-softcams-ultracam-ncam_15.2-r0_all.ipk
- (804.34 KiB) Downloaded 113 times
- enigma2-plugin-softcams-supcam-ncam_15.2-r0_all.ipk
- (2.13 MiB) Downloaded 111 times
- enigma2-plugin-softcams-powercam-ncam_15.2-r0_all.ipk
- (2.13 MiB) Downloaded 116 times
- enigma2-plugin-softcams-gosatplus-ncam_15.2-r0_all.ipk
- (2.13 MiB) Downloaded 112 times
- 2776 Views
