[E² Plugin] FootOnSat
Been thanked: 2741 times
The plugin supports notifications and scanning channels .
enigma2-plugin-extensions-footonsat_1.6_all
- Add new tournaments
- Modify converters to be compatible with py3
- Add the ability to change the order of the tournaments or hide them
- Possibility to move with the UP/DOWN/LEFT/RIGHT button
- HD skin support has stopped
Code:
wget -q "--no-check-certificate" http://raw.githubusercontent.com/ziko-Z ... install.sh -O - | /bin/sh
enigma2-plugin-extensions-footonsat_1-6-deb.2246/
https://www.satsupreme-forum.com/index. ... -deb.2246/
enigma2-plugin-extensions-footonsat_1-6-ipk.2247/
https://www.satsupreme-forum.com/index. ... -ipk.2247/
Re: [E² Plugin] FootOnSat
Update for Version 1.9
enigma2-plugin-extensions-footonsat_1.9-r0_all.ipk
https://www.satworld-forum.com/download/file.php?id=6808
enigma2-plugin-extensions-footonsat_1.9-r0_all.deb
https://www.satworld-forum.com/download/file.php?id=6807
https://www.satworld-forum.com/download ... hp?id=7163
https://www.satworld-forum.com/download ... hp?id=7162
Update Logo FootOnSat
Code:
wget --no-check-certificate https://raw.githubusercontent.com/MOHAM ... staller.py -qO - | python
https://www.satworld-forum.com/download ... hp?id=7368
https://www.satworld-forum.com/download ... hp?id=7367
add F1 Schedule 2025 logos
Code:
https://www.satworld-forum.com/download ... hp?id=7508
https://www.satworld-forum.com/download ... hp?id=7507
Has thanked: 14318 times
Been thanked: 1599 times
[SHOW POST]
