[Plugin] EPGImport
Been thanked: 2741 times
[Plugin] EPGImport
in v.2.2 add iptv - fix list - minor fix
thanks Lululla
enigma2-plugin-extensions-epgimport-dreamos_2.2_all.deb
(85.75 KiB) Downloaded 335 times
Re: [Plugin] EPGImport
with last
-mod path and mountpoints
Thanks lululla
EPGImport.zip
(100.26 KiB) Downloaded 82 times
Dreamos_version 2.4
-Crash on LogMonitor as ben fixed.
-removed scrollLabel
enigma2-plugin-extensions-epgimport-dreamos_2.4_all.deb
(63.74 KiB) Downloaded 344 times
v.2.5
add path in config db epg
enigma2-plugin-extensions-epgimport-dreamos_2.5_all.deb
(64 KiB) Downloaded 318 times
v.2.7 on top
fix - directory choice
Installation:
put file .deb to /tmp with ftp software (filezilla?? dcc)
and install from menu extensions or from telnet with command
dpkg -i /tmp/*.deb
enigma2-plugin-extensions-epgimport-dreamos_2.7_all.deb
(65.37 KiB) Downloaded 308 times
enigma2-plugin-extensions-epgimport-dreamos_2.6_all.deb
(63.64 KiB) Downloaded 341 times
2.8 version on top
now work better
enigma2-plugin-extensions-epgimport-dreamos_2.8_all.deb
(65.46 KiB) Downloaded 343 times
(63.64 KiB) Downloaded 331 times
v.2.9
20.12.2024
enigma2-plugin-extensions-epgimport-dreamos_2.9_all
online
thanks Lululla
enigma2-plugin-extensions-epgimport-dreamos_2.9_all.deb
(65.88 KiB) Downloaded 359 times
-upgrade from telnet command
-with blue button (now) you upgrade direct from @ doglover3920
-fix crash on import
Thanks Lululla
enigma2-plugin-extensions-epgimport_99.0_all.ipk
(408.07 KiB) Downloaded 171 times
