Help to recovery Amiko Viper 4K V30
Been thanked: 2735 times
Public call
Whoever has a functional Amiko Viper 4K V30 at home and can lend a
hand of help , is asked to insert a FAT32 formatted USB stick into it ...
- initiate a Telnet session (PuTTy)
- and copy/paste the following command
Code. root@viper4kv30:~# dd if=/dev/mmcblk0 of=/media/hdd/mmcblk0.img count=128000 bs=512
This command copies the first 62 Mb of Flash (EMMC) at block level and
writes an image file on the stick that can be restored on another Viper V30
... partially functional, reinstalling the Enigma2 image and bringing it back to life!
Please upload the file to MEGA and give a link !!!
thx mihaip
Re: Help to recovery Amiko Viper 4K V30
Here is the result...
Download V20 : https://mega.nz/file/2s9WnZxY#rpjJ44T8D ... Hm0vnw5fi4
Download V30 : https://mega.nz/file/q0MliRZL#35HMWD4RS ... ppM-QFJchw
Download V40 : https://mega.nz/file/7o1wnRZJ#cBo1P0Xhg ... pA4hgaDulM
These are the 3 fast recovery images "usb_update.bin" !
I highly recommend you to use them only in case of extreme necessity !
- format a FAT32 stick,
- write usb_update.bin on it,
- insert the stick into the receiver,
- turn on by pressing GREEN repeatedly!
- the EMMC control partitions will be populated
- after reboot ...
- format the stick and write the desired image folder on it
- insert the stick
- the desired Enigma2 image will be loaded
- after reboot you will wake up in the Start Wizard Ennigma2
I can't end without thanking everyone who helped me!
sosozah, attila, @innersat91 and obviously zildan!
Thx mihaip
lorakus
Poland
Post by lorakus »
witam posiadam dekoder amiko 4k v30 uwalony jest całkowicie usb nie działa wiec ta metoda co wyżej nie zadziała potrzebuje przywrócic go do zycia ta metoda https://www.linuxsat-support.com/thread ... /?pageNo=1 ale nie mam wsadu w takiej po pliku Hi3798MV200-emmc.xml moze ktos posiada albo wie jak to inaczej ogarnac .
