BackupFlash
Been thanked: 2735 times
BackupFlash
BackupFlash plugin for new devices OE2.0/2.5 compatible (py2 & py3)
v9.5 09.12.2024
thanks Lululla
enigma2-plugin-extensions-backupflashe_9.5_all.deb
(736.24 KiB) Downloaded 100 times
Re: BackupFlash
Update online
- Version 10.8
- Some fixes and improvements
- The zip compression feature will only show up with bz2 backups, no need for xz
- The zip compression feature will now work automatically directly with the Convert feature. No need to choose to activate the zip option
opkg update
opkg install wget
wget https://raw.githubusercontent.com/fairb ... staller.sh -O - | /bin/sh
Re: BackupFlash
New online update
- Version 10.9
- Some fixes
- Version 11.0
- Some fixes.
- Added file size in the last notification message.
Re: BackupFlash
New online update
- Version 11.1
- Some fixes
