Bouquet Maker Xtream - IPTV Bouquet Maker (new 2023)
BouquetMakerXtream (BMX) - Official Release
v.1.35_12.07.2024
A plugin to allow the easy creation of bouquets for IPTV playlists.
Based on my original JediMakerXtream plugin, but completely rewritten and code modernised.
BouquetMakerXtream should be compatible with all images and boxes.
Create bouquets for Xtream Codes / XUI One
Create bouquets for external m3u8 playlists.
Create bouquets for local m3u8 playlists.
Categories and individual channels can be hidden
Auto update option
Picons download option
Catchup option via ChannelSelect screen (not EPG guide) for Xtream/XUI playlists if your provider has it.
v.1.35_12.07.2024
Auto update option
- enigma2-plugin-extensions-bouquetmakerxtream_1.35_20241207_all.deb
- (1.12 MiB) Downloaded 162 times
- enigma2-plugin-extensions-bouquetmakerxtream_1.35.20241207_all.ipk
- (1.39 MiB) Downloaded 174 times
Re: Bouquet Maker Xtream - IPTV Bouquet Maker (new 2023)
BouquetMakerXtream (BMX) - v1.36
thanks @kiddac
Attempt to fix the python 2.7 builds.
thanks @kiddac
- enigma2-plugin-extensions-bouquetmakerxtream_1.36_20241208_all.deb
- (1.12 MiB) Downloaded 133 times
- enigma2-plugin-extensions-bouquetmakerxtream_1.36.20241208_all.ipk
- (1.39 MiB) Downloaded 138 times
- kingsman
- Has thanked: 13 times
- Been thanked: 268 times
Bouquet Maker Xtream 1.37
More series amends and fixes.
- enigma2-plugin-extensions-bouquetmakerxtream_1.37_20241208_all.deb
- (1.12 MiB) Downloaded 130 times
- enigma2-plugin-extensions-bouquetmakerxtream_1.37.20241208_all.ipk
- (1.39 MiB) Downloaded 144 times
VU+ duo4K
Multi R84
Multi R84 brutus z
Multi R84
Multi R84 brutus z
BouquetMakerXtream (BMX) - Official Release.
V1.38-20241208
minor fix
thanks KiddaC
V1.38-20241208
minor fix
thanks KiddaC
- enigma2-plugin-extensions-bouquetmakerxtream_1.38_20241208_all.deb
- (1.12 MiB) Downloaded 142 times
- enigma2-plugin-extensions-bouquetmakerxtream_1.38.20241208_all.ipk
- (1.39 MiB) Downloaded 125 times
BouquetMakerXtream (BMX) - v1.39
Removed user-agent - conntection: keep-alive
updated russian translations
Bouquet names - non ascii character fix
Thx KiddaC
Thx KiddaC
- enigma2-plugin-extensions-bouquetmakerxtream_1.39_20241214_all.deb
- (1.12 MiB) Downloaded 132 times
- enigma2-plugin-extensions-bouquetmakerxtream_1.39.20241214_all.ipk
- (1.39 MiB) Downloaded 117 times
BouquetMakerXtream (BMX) - v1.40
Amended custom_sids logic - most providers don't include custom_sids in their api code. So most will see no difference. Tottbeck
pontiak might be worth you testing to.
Slight amend to russian translations
Choose categories should now skip live, vod or series if it has categories but no streams. Some crappy providers do that.
And I was experimenting with downloading updates after deep stand by. I failed.
But I think now if its missed the scheduled time it will download updates after coming out of deep standby or maybe even when turning your box on. Who knows.
- enigma2-plugin-extensions-bouquetmakerxtream_1.40_20241216_all.deb
- (1.12 MiB) Downloaded 122 times
- enigma2-plugin-extensions-bouquetmakerxtream_1.40.20241216_all.ipk
- (1.39 MiB) Downloaded 123 times
BouquetMakerXtream (BMX) - v1.41
Fixed the custom_sid issue (again - properly)
thanks kiddac
thanks kiddac
- enigma2-plugin-extensions-bouquetmakerxtream_1.41_20241218_all.deb
- (1.12 MiB) Downloaded 117 times
- enigma2-plugin-extensions-bouquetmakerxtream_1.41.20241218_all.ipk
- (1.39 MiB) Downloaded 134 times
V1.42-20250110
Switch catchup url to alternaive api call to be more compatible with more providers urie
Updated Hungary translation sasfioka
Removed brackets from file names to be more compatible with other software jagg
thanks KiddaC
V1.42-20250110
thanks KiddaC
- enigma2-plugin-extensions-bouquetmakerxtream_1.42_20250110_all.deb
- (1.13 MiB) Downloaded 123 times
- enigma2-plugin-extensions-bouquetmakerxtream_1.42.20250110_all.ipk
- (1.4 MiB) Downloaded 135 times
- ocean777
- Has thanked: 240 times
- Been thanked: 210 times
BouquetMakerXtream (BMX) - v1.42
20250110
20250110
- enigma2-plugin-extensions-bouquetmakerxtream_1.42.20250110_all.rar
- (1.4 MiB) Downloaded 145 times
