Putty v0.82
Putty v0.82
Putty v0.82
New update:27.11.2024
- Major refactoring of Unicode handling to allow the use of 'foreign' Unicode characters, i.e. outside the system's configured default character set / code page. Not yet complete, but the following things work:
Windows console: usernames and passwords entered interactively into PSCP, PSFTP and Plink can use foreign characters.
Windows command line: usernames, remote commands, and filenames entered via command-line options can use foreign characters.
PuTTY's own terminal (on Windows and Unix): even if it's not configured into UTF-8 mode for the main session, interactive usernames and passwords can use foreign characters.
- Unicode version update: all character analysis is updated to Unicode 16.0.0.
- Unicode terminal rendering: national and regional flags are now understood by PuTTY's terminal emulator. (However, correct display of those flags will depend on fonts and operating system.)
- The Event Log mentions the local address and port number of the outgoing connection socket.
- Bracketed paste mode can now be turned off in the Terminal > Features panel.
- Unix Pageant: new --foreground mode for running as a subprocess.
- Bug fix: the 'border width' configuration option is now honoured even when the window is maximised.
- Bug fix: SHA-2 based RSA signatures are now sent with correct zero padding.
- Bug fix: terminal wrap mishandling caused occasional incorrect redraws in curses-based applications.
- Bug fix: Alt + function key in "Xterm 216+" mode sent a spurious extra escape character.
Download PuTTY: latest release (0.82)
https://www.chiark.greenend.org.uk/~sgt ... atest.html
