Dream Elite Panel 7.2 Released
Dream-Elite Team is pleased to present the new Dream-Elite Panel 7.2.
Below are the instructions for updating from DEP 7.1 to DEP 7.2
1. Before proceeding with update, we RECOMMEND deactivating and deinstalling all active So*tc*ms, deactivating CI+ from CI+ Manager and to choose the standard skin "Default-FHD"
2. Using the remote control and go to Menu - Settings - Software Management - Update Software. At the end it is RECOMMENDED to RESTART the dreambox.
3. You will now have installed the New Dream-Elite Panel 7.2
Some users will have problems to update by remote control. This means that something is blocked. You can check via terminal with the following commands:
Code:
apt-get update
apt-get upgrade
If there is an error please report it on Dream-Elite Forum and we can help to solve this issue
If someone wants to install DEP 7.2 on a new flashed DreamOS they can use the installation guide here on Dream-Elite Wiki
In the next few days there will be also DEP 7.2 ready DreamOS Images on the Image Download Page..
dream-elite-extra_arm64.deb
https://fastupload.io/1cb7af1047fd2d57
dream-elite-extra_armhf.deb
https://fastupload.io/eb7cee76aeb023e0
dream-elite-extra_mipsel.deb
https://fastupload.io/0fe04b396207d7d8
