Portugal vs Poland Highlights
Has thanked: 14329 times
Been thanked: 1640 times
Portugal vs Poland Highlights: POR 5-1 POL, Cristiano Ronaldo scores twice as Portugal enters quarterfinals
POR vs POL: Read the highlights of the UEFA Nations League 2024-25 match between Portugal and Poland, being plated at the Estádio do Dragao in Porto on Friday.
Ronaldo scores brace as Portugal beats Poland to sails into UEFA Nations League quarterfinals
Cristiano Ronaldo scored twice and assisted a goal each as Portugal beat Poland 5-1 in their UEFA Nations League 2024-25 group-stage match, at the Estadio Do Dragao in Porto on Friday.
NOVEMBER 16, 2024 03:12FULL-TIME
FT: Portugal 5-1 Poland
Portugal sails into the quarterfinals after an emphatic victory over the Poles, including a superb performance by Ronaldo, who scored twice and assisted once.
NOVEMBER 16, 2024 03:11GOAL
88’ Too little too late for the Poles
Poland pulls one back as Marczuk finds the net, coming on from the bench but it looks too little too late.
NOVEMBER 16, 2024 03:10
87’ Ronaldo scores again!
Cristiano Ronaldo turns back the block to score a spectacular through an overhead kick, as he makes it 5-0 for the hosts in Porto.
NOVEMBER 16, 2024 03:00GOAL
83’ Neto makes it four!
There is nothing stopping Portugal now and Ronaldo turns provider minutes after the third goal and sets up Pedro Neto, who makes it 4-0 to put the competition to bed.
NOVEMBER 16, 2024 02:57GOAL
80’ Bruno Fernandes scores!
Bruno Fernandes gets the ball and instead of passing it to Ronaldo, chooses to go for goal himself and finds it. He finds the top-left corner with his right foot and Portugal is flying.
NOVEMBER 16, 2024 02:48GOAL
72’ Cristiano Ronaldo scores
The referee points to the spot after Kiwior is found to have handled the ball off Vitinha’s shot. Ronaldo steps up to take the penalty and calmly buries the ball into the net.
NOVEMBER 16, 2024 02:43
66’
Portugal is now dominating possession, riding high on the momentum found through the goal and the loud cheers from the fans in Porto.
NOVEMBER 16, 2024 02:41
63’
Portugal has found a new source of confidence through the goal and Veiga tries a magnificent from a distance but the ball flies off-target.
NOVEMBER 16, 2024 02:35GOAL
59’ Leao opens the scoring
Costa starts play quickly and Portugal marches up the pitch. Nuno Mendes sets up Leao in the box, who heads the ball into the net past Bulka and Portugal has finally found the breakthrough.
NOVEMBER 16, 2024 02:34
56’
Poland is being projected to resounding boos by the home fans as the referee gives the visitors a free-kick for a foul by Dalot. Meanwhile, Portugal steals the ball back and tries to go for an attack but Mendes’ run end with a goal kick.
NOVEMBER 16, 2024 02:29
52’
The home crowd has had quite some moments to complain, with the most important one being the penalty appeal by Ronaldo in the last minute of first-half stoppage time -- an appeal which was turned down by the referee.
NOVEMBER 16, 2024 02:28
51’
Portugal looks much more pro-active in the final third than it did in the first half but Poland is clearing its lines well to keep the score locked at 0-0 at the moment.
NOVEMBER 16, 2024 02:26
49’
Leao drops his shoulder to his right and shift just outside the box to try a right-footed curler, which goes wide. Bulka was unmoved.
NOVEMBER 16, 2024 02:25
48’
Portugal starts the second half on the attack, with Bruno’s cross in the box first blocked and then Neto’s floating cross caught by Bulka.
NOVEMBER 16, 2024 02:22
Second half underway!
The second half begins with three changes. Vitinha replaces Joao Neves for Portugal while Sebastian Walukiewicz and Kamil Piatkowski replace Jan Bednarek and Dominik Marczuk, respectively.
NOVEMBER 16, 2024 02:06HALFTIME
Nothing to separate the two sides at the break!
A tale of missed opportunities sees the contest remain goalless after the first 45 minutes plus stoppage time.
NOVEMBER 16, 2024 02:04YELLOW CARD
45+1’ Golden chance for Ronaldo to score!
Bruno Fernandes floats in a gorgeous ball on the far post for Leao, who serves it on a platter for Ronaldo to score but Bednarek makes a block to deny a certain goal.
Ronaldo thinks it was a foul and appeals furiously for a penalty but his fury is acknowledged by the referee with a yellow card.
NOVEMBER 16, 2024 02:01
Suspension for Bruno Fernandes
In case you missed it, Bruno Fernandes got a yellow card in the 25th minute, which means he would be suspended for Portugal’s next Nations League match against Croatia.
NOVEMBER 16, 2024 01:59
42’ End-to-end action
Neto gets the ball to Bruno, who tries to set up Leao on the far post. But Leao’s header is too high and fails to create any real trouble for the visiting side.
NOVEMBER 16, 2024 01:58
41’ Chance for Poland!
Poland attacks again and this time a cross from the left is deflected out by Dalot. The corner kick sees Piatek get a head to the ball but no direction at all as the ball goes out for a goal kick.
NOVEMBER 16, 2024 01:55
38’ Piatek almost scores!
Piatek gets the ball off Kaminsky and then keeps Veiga at bay to launch a shot, which drifts late to go just wide off-target. It is Poland which has had the better chances in this match so far.
NOVEMBER 16, 2024 01:54
36’
Poland’s injury problems are only exacerbating at the moment with Taras Romanczuk on the ground. After medical attention from his team, he his back on his foot.
NOVEMBER 16, 2024 01:52
35’
Veiga clears the ball in the midfield and slips out of the field. There is no injury and the match resumes immediately. The contest, for now, looks well balanced between the two sides with the score 0-0.
NOVEMBER 16, 2024 01:50
32’ Forced change for Poland!
Kaminsky replaces Bereszynski, who looks to have pulled a muscle after the chance involving him and Nuno Mendes minutes ago.
In: Yakub Kaminsky, Out: B. Bereszynski
NOVEMBER 16, 2024 01:49
31’
Leao gets the ball along the left flank and marches up the pitch. He tries to set up Ronaldo in the centre but Kiwior spoils the party with a timely interception.
NOVEMBER 16, 2024 01:46
28’ Mendes saves Portugal’s blushes
Poland attacks against the run of play, with Zalewski making a run across the park. He sends Bernardo Silva to the cleaners, marches into the final third and sets up Berszisnky on his right.
He tries a low cross for Bogusz but Nuno Mendes makes a block at the eleventh hour to deny a certain opening goal for Poland.
NOVEMBER 16, 2024 01:44
27’
Bereszynski carries the ball along the right flank and wards off his marker to deliver a cross in the centre. However, there is no one to receive it and another chance for the visitors goes begging.
NOVEMBER 16, 2024 01:40
23’
Ronaldo steps up to take the free-kick but the ball sails over the net into the crowd. The Portuguese legend had found the net from a similar position so many times in the past. Not this time though.
NOVEMBER 16, 2024 01:39
22’
Ronaldo, Mendes and Leao try to combine along the left flank but Ronaldo’s mispass gifts the all to the opponent. However, Ronaldo is fouled in front of the box to give Portugal a free-kick.
NOVEMBER 16, 2024 01:38
20’
Poland is marching men forward with Bereszysnki whipping in a ball from the right, which Portugal had almost cleared when Zalewski tries a hit from outside the box, forcing a save by Costa.
NOVEMBER 16, 2024 01:36
17’
Portugal is resorting to zonal marking to deny space to its opponent, which still finds a way, with Bogusz carrying the ball in the final third but his cross is intercepted by Silva for a corner.
Zielinski takes it but Portugal gets a free-kick for a foul on one of its players in the box.
NOVEMBER 16, 2024 01:31
14’
Chance for Portugal to attack. Bruno gets the ball on the right flank and whips the ball into the box. But the ball fails to find a head to connect and Leao misses it too. Seconds later, Bruno gets on the receiving end of a chance wherein Nunes’ cross misses him by a whisker.
NOVEMBER 16, 2024 01:29
12’
Action at the other end! Costa’s goal kick ends on Polish feet but Portugal’s defenders get the ball back. Poland steals the ball back and goes for an attack but the header is finally saved by Costa.
NOVEMBER 16, 2024 01:27
8’
Leao tries to get to the loose ball in the final third and is pushed to the ground for a foul. Portugal’s free-kick is cleared by Poland but it gets a corner in the next minute. That too ends to nothing as one of Poland’s defenders is fouled in the box.
NOVEMBER 16, 2024 01:24
7’
Portugal is unbeaten in the Nations League, with three wins and a draw so far and has come into the match after a draw with Scotland.
NOVEMBER 16, 2024 01:22
4’
Poland tries to attack on the counter, with Zalewski putting in a cross from the left but Costa catches the ball to put the attack to bed.
NOVEMBER 16, 2024 01:20
3’
Portugal tries the long ball approach seconds later, with Bruno Fernandes trying to get to he bottom of a long ball along the right flank. However, he is surrounded by two Polish defenders.
NOVEMBER 16, 2024 01:19
2’
Portugal is looking to enjoy early possession as Leao and Ronaldo pair up in the midfield but Poland forces the host back into its own box.
NOVEMBER 16, 2024 01:17
Match begins!
The players after the national anthem take their positions. Portugal starts in its home kit while Poland begins in its away kit of white. Ronaldo leads the host side while Poland has a two-player attack in front.
NOVEMBER 16, 2024 01:06
Minutes to kick-off!
The players of both teams are done with their final warm ups and have returned to their dressing rooms. The fans are almost set for the game and only minutes remain for the match to begin!
Return to “Sports”
