CyberLink PowerDirector Ultimate 2025 v23.0.1107.1 (x64)
CyberLink PowerDirector Ultimate 2025 v23.0.1107.1 (x64) Multilingual Fast Links | 799 MB
Award-winning video editing software for professional creators. Create. Edit. Share. Video editing, made for everyone. No experience necessary. Do more, faster with customizable templates. Discover and create attention-grabbing video intros alongside our community of creatives.
Mask & Blend
Layer, shape, and blend to create artistic scenes.
Keyframing
Bring dynamism and energy to your videos with smooth animated effects.
Green Screen
Remove backgrounds and create Hollywood-style special effects.
Motion Tracking
Add text and graphics that follow the motion of objects to elevate your footage.
Let AI Do the Heavy Lifting
Simplify your creative workflow with AI-you'll be amazed at how quickly you finish your projects.
Limitless Possibilities, Right at Your Fingertips
Bring your imagination to life with our wide array of tools to help customize your projects.
LUTs & Color Match
Match color to quickly balance or change the aesthetic of your videos.
Shape Designer
Design all kinds of shapes with auto-fit text and keyframe controls.
Smart Background Music
Automatically tailor background music to fit the length of your footage.
Stream, Create, and Share to Any Platform
Create unique videos worth sharing using stunning video templates, an immersive stock media library, and a powerful live stream and recording studio to captivate and wow your audience.
Move, Capture, Edit, Go!
Create videos that bring back the intensity and adrenaline captured with your action camera, with editing features designed specifically for sports enthusiasts.
Action Cam
- Video Stabilizer
- Lens Correction
- Video Speed Controls
- Zoom and Pan Effects
Multi-Video Tools
- Video Collage Designer
- MultiCam Designer
Speed-Up Your Workflow
With Tools Designed to Simplify Editing
Customized Hotkeys
Use hotkeys to quickly navigate the timeline using a combination of mouse & keyboard.
Undock Media Library & Timeline
Control the look and feel of PowerDirector's interface for a personalized video editing experience.
Nested Projects
Add and edit multiple projects simultaneously in your timeline.
Video Pre-cut
Save pre-cut clips in your library to reuse throughout your projects.
Audio Ducking
Automatically lower the volume of background audio as a narrator begins a voice-over.
Voice-over Recording
Record audio directly into your project to create your next podcast or tutorial video.
Operating System
- Microsoft Windows 11, 10, 8/8.1, 7 (64 bit OS only)
- Windows 10 or above is required to use AI tools and features
Processor (CPU)
Intel
- Intel Core™ i-series and above
- Haswell (4th generation) processor: Core i7-4770 (only Core and Xeon branded), and above required for AI features.
AMD
- AMD Phenom® II and above
- AMD A8-7670K and above, AMD Ryzen™ 3 1200 and above required for AI features.
Graphics Processor (GPU)
- Standard Video: 128 MB VGA VRAM or higher
- 360-video: DirectX 11 compatible
Memory
4GB required (6GB or above recommended)
Hard Disk Space
7 GB required
Burning Device
Burning drive is required for disc burning purpose
Sound Card
Windows compatible sound card is required
Screen Resolution
1024 x 768, 16-bit color or above
Language Support
- English
- French
- German
- Italian
- Spanish (European)
- Chinese Simplified
- Chinese Traditional
- Japanese
- Korean
- Dutch
https://rapidgator.net/file/8fae24091ab ... 1.rar.html
