[Plugin] Subssupport
New Update
SubsSupport 1.7.0 r6 py3
* Add subsource.net for language subtitles
* Add novalermora for arabic subtitles
Download
https://www.mediafire.com/file/nr5t3off ... l.ipk/file
Re: [Plugin] Subssupport
New Update
SubsSupport 1.7.0 r7
* fix subdl.com
* add elsubtitle " still need more adjustment "
you can use telnet command with my settings:
wget -q "--no-check-certificate" https://github.com/popking159/ssupport/ ... install.sh -O - | /bin/sh
Download
https://www.mediafire.com/file/jaankbt50pd4njs
New Update
SubsSupport 1.7.0 r8
* Fix tvshow search in subscenbest
* Improve arabic subtitles
* Remove settings from telnet install .
* If you install with telnet , the plugin will be compatible with New virtual keyboard if it was installed
Or install from telnet:
enigma2-plugin-extensions-subssupport_1.7.0-r8-py3_all.ipk
(767.49 KiB) Downloaded 250 times
New Update
SubsSupport_1.7.0-r9-py3
* fix subtitlemora
enigma2-plugin-extensions-subssupport_1.7.0-r9-py3_all.ipk
(771.56 KiB) Downloaded 536 times
New Update
09.11.2024
SubsSupport 1.7.0 r10 py3
* Fix opensubtitle org
* Add a new provider opensubtitle mora for arabic subtitles only uploaded by mora
thanks odem2014
enigma2-plugin-extensions-subssupport_1.7.0-r10-py3_all
https://fastupload.io/78be4bacbda4b113
SubsSupport 1.7.0 R1 py2
* Add novaler mora
* Add opensubtitle mora
* Add subsource
* Add subscenbest
Code: wget -q "--no-check-certificate" https://github.com/popking159/ssupport/ ... install.sh -O - | /bin/sh
Download ipk
https://www.mediafire.com/file/yngas6d7a12sagu
New Update
SubsSupport v1.7 r12
* Fix opensubtitles_com , but you must insert your credentials to retrieve your token and enable download , you must insert in the screen of the provider settings your username , password and API key , you can create your free API if you register in the site , but you only have 20 downloads per day , I hope i get a good feedback for all languages
I hope opensubtitles_com team provide me unlimited API key to insert it in the plugin and so users needs a username and a password only and enjoy unlimited downloads .
* add some local languages thanks to Warder
* a trial to manage subtitles in rar files by replacing old closed rarfile.so by a new open one rarfile.py , the problem now is that most subtitles uploaded in rar format are very old and are ass subtitles not srt subtitles so I will try to add ass parsing in the future .
Download from telnet:
enigma2-plugin-extensions-subssupport_1.7.0-r12-py3_all.ipk
(708.57 KiB) Downloaded 582 times
New Update
SubsSupport v1.7.0 r19
* add ( saved synchronization ) :
after you adjust FPS and choose the correct subtitle line for the event time , you can save this synchronization by pressing "Key 6" , if you exit the plugin or zapping to another channel and return back to the same channel , you can restore your saved synchronization by pressing "Key 5" one time .
N.B: To get the better of this function you should save sync "key 6" and restore sync "Key 5" when there is active conversation in the video .
N.B: The saved data will be stored in " /var/volatile/tmp/subsSupport_delays.json " , and the saved data is linked to the event name .
N.B: This new function still beta , may be improved more later .
* improve some providers with mediaplayer2 plugin , this help in some plugins that depend on mediaplayer2 like Transmission .
Download from mediafire:
https:[/b]//www.mediafire.com/file/nrrwflli6rxq2n5
Download from TelNet:
wget -q "--no-check-certificate" https://github.com/popking159/ssupport/raw/main/subssupport-install.sh -O - | /bin/sh
enigma2-plugin-extensions-subssupport_1.7.0-r19-py3_all.ipk
(811.21 KiB) Downloaded 553 times
UPDATE
2.0.7
1) Fixed import of EPG events for the last "channel_id" of XMLTV used
2) Fixed M3U parser for EXTGRP directive
enigma2-plugin-extensions-e2m3u2bouquet_2.0.7_all.ipk
(2.34 MiB) Downloaded 96 times
enigma2-plugin-extensions-e2m3u2bouquet_2.0.7_all.deb
(2.34 MiB) Downloaded 321 times
New update:
Subssupport 1.7.0 r21
* fix opensubtitle com "you must have API to be able to use this provider"
- now search is working perfectly
- now it search for the 3 chosen language not only the first language
* small fix for arabic providers "Novalermora" & "Subtitlesmora"
Code:
[SHOW POST]
