Linuxsat Panel
v.2.4 online 10.10.2024
changelog=
Remove code unecessary
fix Script Url
fix make_request
fix regex_patterns
reduced source code
Telnet:
wget -q "--no-check-certificate" https://raw.githubusercontent.com/Belfa ... staller.sh -O - | /bin/sh
Linuxsat Panel
Linuxsat Panel
- enigma2-plugin-extensions-linuxsat-panel_2.0_all.ipk
- (1.62 MiB) Downloaded 162 times
- enigma2-plugin-extensions-linuxsat-panel_2.0_all.deb
- (1.61 MiB) Downloaded 103 times
Re: Linuxsat Panel
v.2.5 online
changelog=
fix MenuList (recoded)
reduced source code
You need to update because the server list style has changed
please use this command from telnet:
wget -q "--no-check-certificate" https://raw.githubusercontent.com/Belfa ... staller.sh -O - | /bin/sh > /tmp/debug.log
thanks Lululla
changelog=
reduced source code
thanks Lululla
- enigma2-plugin-extensions-linuxsat-panel_2.5_all.ipk
- (7.91 MiB) Downloaded 235 times
- enigma2-plugin-extensions-linuxsat-panel_2.5_all.deb
- (7.19 MiB) Downloaded 91 times
Re: Linuxsat Panel
20241224 2.6.6 version is online
Changelog:
--Removed skin check on NewEnigma and DreamOs
--Fix Execution Script
--Add Info
Changelog:
--Add Info
