easiest way to test playlist
portacolambia32
Australia
Post by portacolambia32 »
Hi,
What has been the best way to test out playlists? There are so many playlists available and it is difficult to go over all of them. Is it pick one and test out?
Bonus question, is there a player that allows bunching together some urls?
Thx
ARCT1C
Has thanked: 18 times
Been thanked: 2 times
Italy
Re: easiest way to test playlist
Post by ARCT1C »
I am currently working on an M3U/M3U8 playlist checker, i write them to a txt file, and a batch script i made myself will check it online, and interact with the xtream code api to provide the info, that's the info it gives you, it's from a real playlist i checked myself so i'm hiding the details
HTTP M3U Link= http://***.xyz:2082/get.php?username=***&password=***&type=m3u_plus
HTTPS M3U Link= https://bolgenco.xyz:25463/get.php?username=pepeDNcCGdz&password=qFjDYx6ek7cP&type=m3u_plus
HTTP url:port= ***.xyz:2082
HTTPS url:port= ***.xyz:25463
Username= ***
Password= ***
Creation Date= 16/01/2024 00:47:11
Expiration Date= 16/08/2025 00:47:11
Timezone= Europe/London
Max Connections= 1
Active Connections= 1
Trial: No
Allowed Outputs= m3u8, ts, rtmp
Check Date: 08/10/2024 23:17:35
I'm also working on a support for mag ones that give you just the link and the mac, and if i can, convert them to m3u playlist
When I'll finish it, I'll publish it online, and it will be possible to use it with really fast response times entrirely on a browser
I'll reply to this thread again with the link when it will be done
dishead
Been thanked: 9 times
Canada
Post by dishead »
vlc
Been thanked: 2735 times
nwoidaho
Has thanked: 1 time
United States of America
Post by nwoidaho »
SFVIP-Player
SFVIP-Player 1.2.7.81 x64 /x86
SFVIP-Player 1.2.7.81 X64 x86.rar
(40.12 MiB) Downloaded 484 times
dominic990
Has thanked: 4 times
Malaysia
Post by dominic990 »
thanks
Return to “IPTV Free m3u Playlists”
Users browsing this forum: Dot [Bot] and 14 guests
