[E² Plugin] Foreca Weather
[Foreca] update V3.2.9
- change URL to .biz (THX to jup @OpenA.TV)
- some code improvements
- enigma2-plugin-extensions-foreca_3.2.9-e2openpluginsgit20220806-r1_all.ipk
- (577.41 KiB) Downloaded 125 times
Re: [E² Plugin] Foreca Weather
# 3.2.8 recoded ssl and pythonstyle fixed
thx Lululla 2024.10.22
- enigma2-plugin-extensions-foreca_3.2.8_all.deb
- (707.8 KiB) Downloaded 155 times
v.3.3.0
- enigma2-plugin-extensions-foreca_3.3.0_all.ipk
- (581.63 KiB) Downloaded 147 times
- enigma2-plugin-extensions-foreca_3.1.6-r1_all.ipk
- (781.64 KiB) Downloaded 100 times
Foreca plugin 3.3.5
Aktualizacia
Thx@JuSt
Aktualizacia
Thx@JuSt
- enigma2-plugin-extensions-foreca_3.3.5_all.ipk
- (948.87 KiB) Downloaded 116 times
try this.. add in setup , selecion server
if select server is NO: the server are online in to txt in git
or language sigle are the server: nz - ba - com - hr etc
Thx Lululla
Thx Lululla
- Foreca_Last_20241228.zip
- (1015.47 KiB) Downloaded 111 times
v.3.3.6
-removed code unnecessary
-picon changed
-thumb changed
-picon changed
-thumb changed
- enigma2-plugin-extensions-foreca_3.3.6_all.ipk
- (927.86 KiB) Downloaded 136 times
For next version (3.3.7)
test this.
If all ok.. i put 3.3.7 in git
thx Lululla
edit crash, please not use
test this.
thx Lululla
- Foreca_next.zip
- (1.16 MiB) Downloaded 127 times
ok on dreambox.. try on pli atv
thx Lululla
thx Lululla
- Foreca.zip
- (1.04 MiB) Downloaded 92 times
Foreca Weather Plugin
3.3.7 version
git are Update
-removed all file .cfg
-major fix emproved code
-translate language and update dict
-add TV button on main plugin. (open config)
-add fav1 - fav2 and start Home in to config menu
30.01.2025
thanks Lululla
3.3.7 version
git are Update
30.01.2025
thanks Lululla
- enigma2-plugin-extensions-foreca_3.3.7_all.ipk
- (1.02 MiB) Downloaded 137 times
