V8UHD : video level not supported (Astra SES Demo UHD)
V7 series/ V8 series/ V9 series/ V8Finden series/firmware download
V8Finden series/I-FIRE/firmware download
GT series/GTPlayerAPK/GTShareAPK/firmware download
ivfgtmedia
Has thanked: 1 time
Been thanked: 2 times
France
Post by ivfgtmedia »
Hi.
On Astra, with my gtMedia V8 UHD :
UHD1 by Astra : OK (3840x2160 50hz HDR(HLG) 4k2k H265 AC3
SES Demo : KO, video level not supported. Same spec that UHD1, only difference I see is EAC (versus AC for UHD1 By Astra), It seems to be the Digital Audio Compression standard used for these channels.
I don't understand why it works fine with the Channel UHD1 by Astra and NOT with SES Demo.
Can you try SES Demo UHD on Astra with your gtMediaV8Uhd, to check if it's a param problem on my config, or hardware incompability.
Any help or advice or explanation wil be apreciated.
Thks, super Forum.
ps : I knew only the freesat forum, but it seems to be dead, excepted for Firmware Downloads.
Very very very happy having joined mail.sat-forum.net !
ivfgtmedia
Has thanked: 1 time
France
Re: V8UHD : video level not supported (Astra SES Demo UHD)
Nobody Can try ? No help ?
Been thanked: 1668 times
ivfgtmedia
Has thanked: 1 time
France
OK, thks.
Ambar89
Been thanked: 1 time
India
Post by Ambar89 »
I’m getting the error V8UHD: Video level not supported while trying to play the Astra SES Demo UHD. Has anyone encountered this issue? It seems like the video signal or format might not be compatible with my setup. Any tips or solutions to fix this would be greatly appreciated.واتساب الذهبي
Return to “GTMEDIA”
