OTT Navigator IPTV v1.6.7.1 buid 22060600 [Premium] [Lite Mod]
Overview: View your provider IPTV on any device (phone, tablet, TV, TV-box).
* Does not provide any video by itself. Works with your provider playlist or another source provided by you *
Live streams:
- live TV watching
- groups favorite channels and categories automatically
- start playing last channel on launch
- timeshift support for providers with archives
- PiP picture-in-picture mode (and studio mode for watching multiple streams)
- reminds interesting shows
Archive/Catch-up:
- watch archived shows and media library
- filters by channels, categories, genres, seasons, years, favorite channels, age, country...
- search by anything
- retrieves data from several EPG sources (including user-provided)
- saving playback progress with automatic resume from previous moment
- playback speed
Network:
- browse and play local network files via UPnP/DNLA
- media library
And lots more, including AFR support, DRM support, recommendations, etc!
★★★ Mod by Alex.Strannik ★★★
Unlocked PREMIUM
Removed analytics
Languages: 'en' 'be' 'de' 'es' 'fr' 'it' 'pl' 'pt' 'ru' 'uk'
Architectures: armeabi-v7a, arm64-v8a
Total apk size: 6.7 MB
- lists: option to enable cyclic navigation between categories (using L/R)
- lists: new compact view type with channel numbers
- player hud: allow to move buffering/brightness/etc status to different parts of the screen
- player hud: new clear variant #5 added (supports both top and bottom)
- vod: deny entering ATV group if restriction is configured
- vod player: support active edges to change brightness and volume
- vod: setting to use provider order for media library
- just started: allow user to remove certain channels or categories from this suggestion
- epg: allow to change epg shift for a provider
- playlist: support for portal:: link providers
- new wallpapers
- config: action to reset RC to default settings
- afr: better support for slower devices that skips frames on some streams, leading to unstable fps calculation (that triggers afr switch), applies for cases when stream does not declare frame rate by itself
- player: setting to set huge clock size
http://ul.to/ls0zo3u3
